Hi everyone!
I was about to finish the repair of a Tudor Prince Oysterdate when I realized that the crown tube is broken and the crown was spinning on itself. This is an early Tudor with a Rolex Oyster case and also a Rolex crown. Pretty bad news as these crowns are expensive... but it is what it is.
Anyway, I know that the crown measures 5.3 mmm, the crown tube seems to measure 1.75 mm and fits a 0.9 mm stem thread.  The crown has a rolex coronet and a small straight line under it. However, I am not sure about the reference number and I can't find anything online for that specific Tudor model. Does anyone know which is the reference number for that crown?  Is it 24-503-0? I am looking at 100-150 USD and the last thing I need is to buy the wrong one.
Thank you in advance!
Cheers,
Ignasi
Edited by ign03
Images added
  • ign03 changed the title to Rolex-signed crown for Tudor Prince Oysterdate 7966?
Crown tubes are friction fitted, so I'm wondering if it would be possible to repair?  I haven't heard anyone talk about doing so but it's worth a try.  If you could remove the tube a small amount of epoxy might secure the tube.
I'm waiting for the others to tell me I'm crazy.  Hehe.
As @RichardHarris123 said I think it's worth a try to fix with some sort of adhesive and maybe try and crimp the tube afterwards.
Edit
Not sure if it's a typo but think the part number could be 24-530-0
What's the watch details?
Edited by AndyGSi
I'm not sure if the part that is broken is pressure fitted or it's part of the crown. And yes, it was a typo, I was referring to 24-530-0, but don't know it for certain. The watch is a 1960s Tudor Prince Oysterdate, Ref. 7966 with a Rolex Oyster Case, cal 2426.
This shows the hex head stem part pressed into the crown.
Edit
Based on your 7966 Reference this is the Generic Crown from Cousins.
Edited by AndyGSi
  • Similar Content
    • Did you just swear at me matey?? I’m sorry, I’m not divulging personal information but there’s always personal reasons. There’s not much more than I can do other than plod along as best I can. However, my health is good now and I’m regularly getting plenty of exercise to keep it that way 👍 You know what. The ads don’t even cover a small percentage of what it costs to serve this site. I find most of it personally. If there are complaints then so be it. I do my best.  in fact - I have zero issues turning them off. Would that make the complainers happy?
    • Same question that was asked last time Hakan, and emphasis was placed on it. It was ignored. The thread should still be there, if not I have a copy of his reply.
    • This is probably the single most important point. One of my best friends, 48 years old at the time, suffered a massive stroke about 15 years ago. He barely survived, but his life was never the same after that. If you had asked me back then to guess which of my friends might have a stroke and nearly die, he would have been the very last one I'd have picked. He was perfectly healthy, played tennis three times a week, ran a successful business, was full of life, and had a wonderful wife and well-behaved teenage kids. The harsh truth is, we never know when it’s "game over." @Mark, I truly wish you a long, happy, and successful life. But have you given any thought to some kind of backup plan for WRT in case the worst should happen? Is there anyone who could keep the site going? If you can reassure us in some way, it would mean more than a lot to us!
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
