Hi,
I am a hobby collector, my absolute favorite watch brand is Certina, and the DS 59-68 line. Especially cal 25-45. But also the cal 25-36, 25-65 and 25-651. I am truly inspired by the wonderful Certina DS collection during this time period. I as a hobbyist I also started to service the watch and find this forum.
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
