Looked like the tip of the hour hand was catching the shaft of the subdial - there's quite a bit of play in that hour subdial so I'm guessing each time it caught it stopped it a little to the point where it was at the bottom end of its range of play - assume I missread the four hour difference as I only saw it once.
I've had a fiddle and will see how it behaves...
A little update on this - all seems to be behaving since refitting the subdial hand. It hasn't had too much wear as I've been away, but in the few days prior to leaving I had no issues and it's behaved while away.
Think I'm calling this one done! 🙂
Yeah, it's not behaving! I'm four hours fast again on that subdial. Who knows - while I have a set of spares from the movement I removed I think it's beyond my skillset and will probably stay in 'dual time mode'(tm)!
  • 3 months later...
Had another crack at this - the hour sundial hand stayed at around 4 hours fast, so I figured it was time to remove and reseat it... I'll be back in a month or so!
So it ended up about 13 hours out somehow! I thought there was an issue with the hands catching (related to my relume) so I took off to fit another pair, one of which killed the plastic hour gear!
Not gone well then, though fortunately I kept the old movement for spares, so I've managed to get it all back together and working today after much messing with the date change...
I wonder if the date change gear was causing issues, though might be that I reassembled wrong - it wasnt happy but after changing the gear and plate from the other movement it's all working again.
I'm really hoping the hour hand issue is sorted - feel like I deserve so e good luck on that front but won't know for a week or so... I'm likely out of my depth here!
A picture to mark the rare occasion that hour dial is more or less correct!IMG_20241206_125943.thumb.jpg.c744911bed1583ad085535bf76068ea2.jpg
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
