Hello all! I'm tIB from the UK up in the peaks near to Bakewell.
Here after stumbling across lots of useful info while searching out answers to endless questions - it's a fantastic resource you folks have put together here.
Hopefully one day I'll add something of use to someone, meanwhile thanks for having me!
Know the area well, having previously lived in Chesterfield and cycled regularly. A good place to quietly contemplate the scenery and a watch movement. Welcome to the forum.
Thanks for the warm welcome folks. Area wise we never really planned to live here but it seems life worked out pretty well in that regard - we lucked out!
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
If there is anything we can help you with don’t be afraid to ask. Nice clear photos can help a lot.
    • Hi. It’s either riveting or welding . I have seen some small home made welding tools on UTube at times may be I should have a go at building one, they are small spot welding machines. Suitable for the likes of these type jobs.
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
