Hi everybody. This is my first real thread here (except my introduction post) and sadly it's not related to a mechanical movement, but a cheap quarts.
A friend of mine had given his old dive watch to his son, but it stopped. Someone (not sure if it was a watchmaker) changed the battery, but this only fixed the problem for a short period.
450930804_750645510371840_4595175783327649387_n.thumb.jpg.6723174e8e2266ae8e7fdd8474d5dbca.jpg
So he dropped it off for me to look at. Im new to watchmaking in general, but when it comes to quarts my knowledge is about zero. I have changed some batteries before. Thats pretty much it.
449232960_474176352015448_4160768418640019997_n.thumb.jpg.9cc1072a9785d8ceecec648d25767205.jpg
Shouldn't something be keeping this movement in place? Is something missing?  What are the two holes in the back?
I did try to put a new battery in, but its impossible to "click" it into place. It just pops right out, and I can't see anything that is supposed to help it stay in place. Do you see anything wrong here?
449320464_1540012070199599_6699649326964640425_n.thumb.jpg.8aca6584f711b3c39843ebf54ef7aa06.jpg449927081_1423732785002333_3688277201366814897_n.thumb.jpg.22b8710cf7aa3d92becb2631a7af480f.jpg449713390_1058287412558984_3433412262227924026_n.thumb.jpg.43bfd28a972f47611aaa852eeb1114f2.jpg
Here is the battery, I have double checked its the right one:
450411837_465516956321977_2291700557673779970_n.thumb.jpg.7335dc8203a5546c42436789f80fdec3.jpg
I could use some tape and paper together with the back of the movement to press the battery in place, but this seems a bit sketchy right?
The watch works as long as I press in the battery.
I would be very thankful for any help!
Difficult to tell from your photos but have a look at the attached, the bit that pushes against the positive side looks different.  It might need slightly bending.  Please be aware, I don't work on quartz.
8 minutes ago, HectorLooi said:
image.png.75c619dca8d868af3b33fb3f0732b8a6.thumb.png.46e549692c96860e1bab4a1b43acd5fc.png
The battery needs to go under the two ledges arrowed in the above picture.
The Battery doesn't go under them it presses against them with the smallest of hooks on the right which is missing off the OPs.
Edited by AndyGSi
Thank you so much. This part seems to be missing from this watch, unfortunately. I see that I can buy a whole new movement very cheaply. Would you say it's easy to put in a new movement? I could have done it with a mechanical watch, but I know nothing about quarts.
I'm surprised you can find a cheap NOS 7N36 but if you can then it should be a simple swap of stem, dial & hands.
Edit
Make sure the new movement is also marked with a 2 as this is the hands height.
Edited by AndyGSi
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
