Hello everybody,
I came across this while I was searching the local sites for watches or tools but I'm not sure it its worth the time or the money (it's not that expensive but still I don't want t o waste my money)
In my opinion: probably not worth buying. If this is the whole tool for sale, and it is not provided with a set of 50 or more stakes, this won't be helpful to you until you also spend considerably more on a set of stakes. But those are not often sold independently of the staking frame tool. So you will be better off searching for and buying a complete or nearly complete staking set.
The one stake that is pictured does not appear to be in a usable state. It is deformed from hammering with a steel hammer and might even be seized or wedged inside the tool.
Wish I had seen that when I first started to be interested in a staking set. You don't say how much it is on sale for. A good DIY project.
I had one like it. Mine had a 4mm  stake gap. I made a 3mm holder for a £12 box of cheap stakes. Works perfectly. Made an extending base base and adapted some of the 4mm stakes to fit the rotation base. Even made some stumps.
I'd go for it.
This is what I achieved.  Have a read and see what can be achieved. Just seen a set like this on ebay today, starting bid at £200.
If you posted this and said "I've found this staking tool and it costs £1000 and I want to know if it is worth spending my money on." It would be very different from "I've found this staking tool and it only costs £10, do you think it's worth buying?"
To give you any informed answer, you have to first provide some important information to base our answers on, like the price of it!
To be honest, you are going to find a good Favourite or other known brand of staking tools and all or most of the anvils and stakes for about £150 to £250.
If this is under £50 I would probably buy it and find the other bits and pieces needed, but that can be a pain in the ass, so it's back to buying a complete set.
It depends what kind of person you are. I Ilke to buy something and find other pieces to go with it, especially when it comes to watchmaker's lathes and all the attachments and countershafts, chucks, etc. But some like to have it all now. I suppose it boils down to 'delayed gratification.'
Having a psychotherapist as a wife has its upsides! 😂
Edited by Jon
About the price of the brand new complete one …
Pretty sure OH wasn't meaning your Diy skills Ross, i would certainly hope not anyway. Its related to the old staking tool at the start of the thread.
Yes that is right. No offence intended.
I must say I'm the same, buying a complete set of something saves a lot of time and effort but there is a certain type of gratification for me hunting out all the add-ons.
Ps hands down having a psychotherapist for a wife is way better than having a psychopath for a wife in my experience 🙄
I had to state the price sorry everybody, it around $25.
I like to do the same, hunt for bits and peices but the problem is it's not that easy where I live I'd probably have to wait years to find the complete set and importing from abroad isn't an option because of the huge shipping and customs costs so I think I'm gonna pass on this one.
8 hours ago, oldhippy said:
What a load of crap. Were you drunk at the time?
Ok ok will delete it from all my browser and apps history, sorry! 🤣🤣🤣
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
