Hello everybody,
I came across this while I was searching the local sites for watches or tools but I'm not sure it its worth the time or the money (it's not that expensive but still I don't want t o waste my money)
In my opinion: probably not worth buying. If this is the whole tool for sale, and it is not provided with a set of 50 or more stakes, this won't be helpful to you until you also spend considerably more on a set of stakes. But those are not often sold independently of the staking frame tool. So you will be better off searching for and buying a complete or nearly complete staking set.
The one stake that is pictured does not appear to be in a usable state. It is deformed from hammering with a steel hammer and might even be seized or wedged inside the tool.
Wish I had seen that when I first started to be interested in a staking set. You don't say how much it is on sale for. A good DIY project.
I had one like it. Mine had a 4mm  stake gap. I made a 3mm holder for a £12 box of cheap stakes. Works perfectly. Made an extending base base and adapted some of the 4mm stakes to fit the rotation base. Even made some stumps.
I'd go for it.
This is what I achieved.  Have a read and see what can be achieved. Just seen a set like this on ebay today, starting bid at £200.
If you posted this and said "I've found this staking tool and it costs £1000 and I want to know if it is worth spending my money on." It would be very different from "I've found this staking tool and it only costs £10, do you think it's worth buying?"
To give you any informed answer, you have to first provide some important information to base our answers on, like the price of it!
To be honest, you are going to find a good Favourite or other known brand of staking tools and all or most of the anvils and stakes for about £150 to £250.
If this is under £50 I would probably buy it and find the other bits and pieces needed, but that can be a pain in the ass, so it's back to buying a complete set.
It depends what kind of person you are. I Ilke to buy something and find other pieces to go with it, especially when it comes to watchmaker's lathes and all the attachments and countershafts, chucks, etc. But some like to have it all now. I suppose it boils down to 'delayed gratification.'
Having a psychotherapist as a wife has its upsides! 😂
Edited by Jon
About the price of the brand new complete one …
Pretty sure OH wasn't meaning your Diy skills Ross, i would certainly hope not anyway. Its related to the old staking tool at the start of the thread.
Yes that is right. No offence intended.
I must say I'm the same, buying a complete set of something saves a lot of time and effort but there is a certain type of gratification for me hunting out all the add-ons.
Ps hands down having a psychotherapist for a wife is way better than having a psychopath for a wife in my experience 🙄
I had to state the price sorry everybody, it around $25.
I like to do the same, hunt for bits and peices but the problem is it's not that easy where I live I'd probably have to wait years to find the complete set and importing from abroad isn't an option because of the huge shipping and customs costs so I think I'm gonna pass on this one.
8 hours ago, oldhippy said:
What a load of crap. Were you drunk at the time?
Ok ok will delete it from all my browser and apps history, sorry! 🤣🤣🤣
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
