Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
If there is anything we can help you with don’t be afraid to ask. Nice clear photos can help a lot.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
    • Thanks Mark I have uBlock Origin Lite add-on for my Windows Chrome browser, so I've never seen a single ad on this site ! It also removes all adds from Youtube - I couldn't bear to watch it without uBlock
