Good day everyone!
Once again, I am in need of your assistance.
I have an Omega cal. 321 in a CK2907 case that was/is not running. Upon first inspection, I found that a broken winding pinion was blocking the movement. While taking the movement apart, I noticed some dirt in the channel where the chrono minute shaft goes. A closer look revealed that the shaft where the stem end rests was damaged, assuming due to the watch falling on the crown at some point?
As a result, the two channels were interconnected, and the residue from the keyless works spread, causing wear on the top of the main plate.
Please advise. Is this repairable? What options do I have?
32 minutes ago, RichardHarris123 said:
The only solution I can see is to bush it.
definitely would be an option if I would have had proper tooling.
now that Im thinking, the proper question would be, is there anyone from Switzerland who would be willing to help?
First of all, the whole assumption is wrong. The truth is that the holes are interconnected by defoult. Clean and lubricate the movement and enjoy it, no point to wоrry.
If thats true I wonder where did all that bronze come from.
The problem is that the hole is a bit too large, and the shaft has to much shake.
Edited by swiss2k
2 minutes ago, nevenbekriev said:
And I supose You believe this will prevent the movement from normal working?
Define “normal”.
The movement will run just fine. But I believe when I will set the minute hand, it might potentially touch the dial, and thus cause problems.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
