Do you think they couldn’t pop the “spring bar” off so they decided to cut it off? 😵‍💫
…shame. It’s a beautiful watch. The movement looks and acts like new 🙁
Edited by rehajm
32 minutes ago, rehajm said:
Do you think they couldn’t pop the spring bar off so they decided to cut it off? 😵‍💫
Fortunately it's a fairly easy repair on that one.
Alec
…shame. It’s a beautiful watch. The movement looks and acts like new w🙁
Looks like a fixed lug bar to me, which is why it didnt pop off,  ahhh i see sarcasm
Good way to spread the lugs as well, snipping the pin with nippers.
How would that work?
I think Joe means a simple one piece leather strap to thread through.   Common leather strap on ?  not from around where i live matey, dont know bout you Rich i but I'm still old school  🤣 . If it aint working pop a pill.
 You slightly bend a half of the bar, to fit the leather strap on the other half, then slightly bend  the side with the strap to the same height as the one you bent before and manouver in the half bar into the tube of the strap, finish by  bending  back both halves of the bar to a straight bar as if one bar.
 You can drill out a hole in the lug, but might find the bar comes out as well ,  leaving a wide hole, too wide to fit in a spring bar.
Edited by Nucejoe
That sounds like a risky manoeuvre that could bend the lug as well if its not supported. Then trying to re-align the pins with the strap fitted sounds fun. I'd prefer altering the strap, unpick the stitching and re-sew it.
That is not a spring bar it is molded to the case. Open ended straps are for this type. Now it has been cut you will have to drill holes each end and fit a spring loaded bar, then you can fit a stitched strap or whatever floats your boat.
  • Thanks 2
👍  that's how it was meant to be.
I’m going to have to be more earnest with this group…🥵😂
Yes, fixed lugs on all The Dirty Dozens. This particular one is like new-It’s mind boggling to me why someone would cut the lug to…fit a spring bar strap instead of cinch or glue a fixed lug strap…
..was it a 🏴󠁧󠁢󠁥󠁮󠁧󠁿watch repair shop? C’mon, confess if you’re out there 😂
…something else fun with this one…
See it?
Fun fact: Vertex is the only British Dirty Dozen supplier…🤪
Edited by rehajm
I don’t know what the equivalent watch term is but in classic automobile terms this Vertex is a ‘garage queen’, broken lug and all. I am very very reluctant to make mods or remove scratches on military collectibles. Mainsprings and crystals are consumables but even there I try so save them…
Haha, i did say " ahh sarcasm " 🤣 . You gotta get up early to catch me out with that style of humour.
Recently re-established if I'm not mistaken , by the grandson of the original importer in the UK.
I have something special coming,  its not in a military case but this watch does house the KF 320 .
Edited by Neverenoughwatches
You get me!!😂
I’ve seen a couple fixed lug mils like that 👍🏻
Grana! I speak for everyone…pics please 🙏!!
Yes, Ty…and I think  those thick spring bars look clean in that type of repair…there’s still the other fixed lug which may be an issue with a spring bar/stitched style strap but a nato or pass thru isn’t going anywhere 👍🏻
Edited by rehajm
Personally, I would repair it as it is rather than drill holes for spring bars. I have done three fixed lug repairs in the past couple of months and am probably doing another one in the next few weeks, although the owner has not yet decided whether they would rather keep the originality of the fixed lug or have more choice of straps.
The OP's example is a very straightforward one to repair, in practice a lot less work than drilling out spring bar holes well at both ends.
Alec
I would use a touch of solder to fix it.
It looks like a cal 59? I have the same movement in a gold case with fixed lugs. One of my favourite watches. Nice quality movements.
Vertex are British the same way Rolex are.
I like the look of their Dirty Dozen inspired Heritage model :
Edited by mikepilk
I forgot to ask and you mentioned something.  Was there only one clipped lug on the Vertex?
Yes…
Yes, and maintaining originality is important in this case so that’s how I’m leaning at the moment. Ty…
Thanks- solder may be the way to go…I’m kind of amazed at the quality of the movement. Mine was out of beat at just over 2ms but one turn of the collet has it zeroed and running like a chronometer…
…that heritage model is classy…👍🏻
Edited by rehajm
The simple ideas are the best Mike, make it back as it was. For Vertex if i can remember,the UK importer appeared to portray Vertex as British.
Yes…
Strange just one, if the idea was to slide a strap between the cut then why just one ?
I know, right? I can only imagine they thought the spring bar was stuck. their surprise when they learned the mistake
You don‘t want to drill holes in the lugs here.
9 hours ago, HectorLooi said:
Cousins has female spring bars. I'm wondering if the fixed bar could be cut off in the middle, leaving 2 short projections on each end for the female spring bar to latch on.
Exactly what you can do, but originality will be lost a little bit.
That is what I would do.
But not at all soft solder - then you better do nothing - it will prevent any future proper repair. Use silver solder for repair.
Frank
Thank you Frank…general purpose okay? 40 precent?
I imagine to clean a Dirty dozen watch, you ought to give two dozen baths in ultrasonic. 🤣
Well a serious question, is replacing brass bushing holes with jewels an improvement ?
Edited by Nucejoe
Add question
It looks like the case and the bar are stainless? If so I would would use TIG with 316 filler. Once polished back it would be invisible. If it actually brass or nickel with the plating in excellent condition then I would use a silver alloy (technically a braze rather than a solder due to melting point). I usually use Silver Flo 55 which is relatively low temperature and cadmium free.
If it is stainless then using a silver filler is possible but the fluxes are sufficiently nasty that I prefer to weld, plus it leaves a neater result in the end.
If it is brass or nickel then the bar is likely to be brazed in. You can't tell whether the filler you are using is higher or lower melting point than that holding the bar in place, however with a fine enough flame you can get the heat into the ends of the bar before the lugs heat up. Some support and heat shielding by using clay would probably be how I went with it, unless I was feeling lucky. This also helps to avoid plating being damaged beyond the immediate region of the joint.
Alec
