Did you ever compare the bridles H , length thickness and stiffness ?
Yes, I did, and they are not the same. Even so, the feeling of the springs is completely different. The Seiko/Orient springs feel considerably softer and the Swiss springs much stiffer. Seiko/Orient springs easily deform if you don't handle them carefully.
This is another reason, except for the super tiny Diashock springs for the escape wheel and the third wheel, why I avoid Seiko/Orient movements. Anyway, the next time I service a Seiko I'll try Alex's method. He demonstrated it on a balance Diashock spring (not too challenging) but told me in a comment that his method should be working on the other Diashock springs as well. It remains to be investigated.
I avoid them as well, getting parts seems like a lot of trouble.
I can't believe people have so much difficulty getting hold of Seiko Parts.
I know some parts are getting rarer but I've never had any problems.
I think you have to be in the know to know where to go.
Your movement is eta2790 which beats 28800bpm
But you have replaced its mainspring with one for ETA 2750.  which beats 21600/ hr.
Jules borel lists different mainsprings for the two calibs,    do they interchange ?
No they don't interchange but this has nothing to do with the vph and is because one is Manual and the other is Auto.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
