Hiya watch people , does anyone know what this crystal lift is about please.  There are 7 sizes and a couple of steel adapter inserts for this set, but the top holder is a lift out tray with another 8 spaces for more sizes.
1 hour ago, watchweasol said:
Hi @Neverenoughwatches I have one like that myself but never used on anger. The dies fit over the crystal and compress it from the sides I believe. Did you get no instructions at all.
Hey WW hope you're getting better me old mate, so there are instructions in the lid of the box though i haven’t actually read them yet, but I'm sure they operate in the way you say, similar in principle to the claw crystal compression tools, Omega also do some very similar that draw a cut steel ring into a tapered sleeve ( would love to get my hands on that set but very expensive with that Omega tag ) .  My main reason for enquiry is regarding the sizes and if anyone has a bigger set as mine has room for 16 split dies in total and they also had available some steel split ring inserts to adapt each die to inbetween sizes. Very nifty well built tool actually.
Hi @Neverenoughwatches getting on ok , busy working on French clocks a5 the mo and a Viennese in the que with a barometer to come in plus a Russian ships clock giving me the willies, runs for days then has a bad hair day.   My set is like yours bottom tray empty so where they went who knows, it’s still in the drawer.   How’s you .
Good that you are busy, can't keep a good man down 👍,and the ship's clock sounds interesting and troublesome.  I think the bottom tray is if the repairer wants to add extra dies I have another set that i picked up for just a fiver, this has exactly the same seven dies but no lift out tray, strange. I wasn't too impressed with its gripping ability on a generic crystal, looks like I'll have to treat myself to a Tissot seastar seven to find out if these lifters actually work 😅. So i'm good thanks Iain and my mum is doing really well, still struggling with her speech but she's not letting it hold her back, shes out almost everyday and often on her own.
I had that opener, it is for the seastar seven I never used it I found you easily remove the glass with the good old faithful  Vigor Bergeon.
Thanks OH, its good to get a few folks view on tools. Looking at the tool the crystal would need a good high dome for it to grab.
  • 5 months later...
Sorry for replying to this old thread - but in case you’re watching… I’ve been going down this rabbit hole with a Seastar seven that I’m trying to open. I’m getting the Bergeon claw tool and I’m interested to see you say that you can use it on the Seastar seven. Just to confirm was it successful at removing and replacing an armoured crystal?  Thanks.
    • Hi guys. @VWatchie Those images are self hosted (not hosted on this server). Do a look at the page source and you will see this. I’m afraid, I can’t have control or backup images not hosted on this server. This server is backed up fully every night and the database is backed up and versioned every hour, all stored off site on Amazon S1 platform. It’s hard for us to lose data. Ive got a huge overhead of space on this particular server the site is served from so no worries there 🙂 Sorry all for lack of response so far, I have been extremely busy and am embarrassed to say that priorities had to be set in place for a while.  Be assured that i’ve got constant monitoring and alerts should the site be in an extended problematic state (down etc) and work on these issues if they arise.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
