Slipping Anchor pallet
dnhb
Working on a friend's Bracket clock (Westminster chime) I noted it needed a rather extreme tilt to get in beat. Adjusted the crutch to reduce this & clock ran to time for a day or two but then stopped. On attempting restart it's clear the Anchor pallet has slipped/rotated laterly on its arbour. This one, unlike the other I've fixed, doesn't have a screw with which to secure it on the arbour. Are there any other fixes other than drilling & tapping this one?
As I feared the complete pallets are pushed/ hammered onto a tapered rod. You will have to take the complete unit off before you mark where the should go. You need to close the hole by using a stake punch around the hole so it is a tight friction fit. You could also use some locktight, blue is strong but easy to move red is stronger and more permanent.
The movement is Gustav becker which is German.
Edited by oldhippy
