Going out of mind here with low amplitude on a 7s26 and can't fathom why. ANY suggestions for fault finding would be great. I'm ready to throw in the towel.
By nickelsilver · Posted
Hi, I was wondering if you had been able to find the crystal reference code for the 0903-7030 I'm in a similar predicament. Thanks.
