Brand owner - here to learn and contribute.
Interesting. It also seems strange that it’s only the jewel on the top of the balance that has the grove and not the one on the bottom. I guess maybe one of them got replaced at some point. I’ve never used Fixodrop but I think it’s something I will look into to. Can I just ask how you use it when oiling the cap jewels?
So far there are no bids on the faceplates, while almost everything else has several bids. So I am hopeful they'll stay cheap. There are several Levin cross slides too probably for less than ebay prices, but I don't know that I'll be able to spend that much at this time.
You can never have too many lathes...😀
Well I guess I'll have to buy a bigger lathe at this auction then! (there are many, many of them available)
Both my ww lathes are a tiny bit over 50mm, so I guess 4" should just work. And, if needed, using a bigger lathe to reduce the diameter is easy.. If they're cheap: go for it!
