1980's Seiko Chronograph Bezel missing
Exactly, that's why I wanted to ask.
You're right. My first measurement was done using a guessometer (calipers). My 88,8mm diameter faceplate just clears a 5,6mm stack of gauge blocks. So: exacly 100mm. The relieved center might indeed give you a bit extra. But, stepping a bit: It wouldn't make sense for a faceplate manufacturer to make a faceplate that wouldn't fit most 8mm lathes. So 4" is not very likely.
By Martingazzashea · Posted
Hi all, Does anyone know where I can purchase or get made Watch crowns for the Vertex Dirty Dozen watch, I need about 20 number -
Look for Citizen 5400, 5410, 5420, 5430 & 5470 as members of a family. 5400 is likely to be the base caliber. Balance complete of any of above calibs would fit the others. Normally most parts of the base calib interchange with all members of the family. Regs
