I am servicing an ETA 1093 which has a number of pivots with cap jewels. This looks like a way to up the jewel count for marketing purposes rather than serve a purpose as pivot jewel.
I have tried cleaning the cap jewel, reinstalling dry and the using an auto oiler from the other side (not sure the oil is getting into the jewel). I have also cleaned the cap jewel, added a spot of oil and then installed (this seems like too much oil and not sure it is getting to the pivot end). Neither of these techniques seem correct.
Before I tear it down and reclean again, would it be OK to apply oil to the jewels directly in the usual manner/ quantity and then reinstall the clean cap jewels?
Screenshot_2024-08-14-09-21-15-27_99c04817c0de5652397fc8b56c3b3817.thumb.jpg.7ce5753abff730a66145c8db6ab4221f.jpg
Screenshot_2024-08-14-09-20-29-90_99c04817c0de5652397fc8b56c3b3817.thumb.jpg.c4402e5e8c0192ad32ec3fdcb388338a.jpg
1 hour ago, VWatchie said:
I had this same question several years ago and got excellent advice which I still use.
Excellent, thank you. The ETA 1080 is the base movement for my 1093, so has a lot of similarities.
I tried using the auto-oiler but I don't think the needle actually went through the jewel. When I removed one of the cap jewels after oiling there wasn't any visible oil on the cap stone.  The Seitz manual seems to uggest that oiling through the jewel is the best way.  I have a broken oiler that i can try and stone down to use as a 'pusher'.
Oiling the cap stones seems a bit hit and miss - the ones on the dial side particularly as they are not actually located by anything other than the screw and so rotate slightly when you are tighteneing them up.  This would just serve to spread the oil spot around.
They are considered an upgrade on a movement,  sometimes the end pieces are missing and the holed jewel is traditional with an oil sink on the outside of the plate with a matching pivot shape for that jewel manufactured as such. They do serve a purpose and that is to reduce train friction, more significantly in the smaller wheels and lever. Remove, oil and replace, the installed wheel's pivot will reach and ride in the oil, the cap sets the endshake, do not mix up the endpieces as they may differ in depth set .
This is one of those tasks which starts as a real nuisance, but once you have the technique, becomes quite easy.
I have a ground down oiler which works well, but you have to keep the tip really sharp. I also made a copy of the Horotec Incabloc oiler (which is designed for this task)
by gluing an old balance staff in to some brass tubing (which was stuck on an old oiler).
I put a blob of oil on the jewel, push the oiler through the hole and wait for a few seconds, then turn the jewel over to check the size of the oil circle. Repeat until enough oil gets through.
I actually have an old balance staff set into a piece of pegwood that may be ideal for this.  Maybe I will try that.
I made it as compensation when I managed to completely mangle the hairspring on a (fairly) rare Pobeda movement with centre seconds so I wanted to make use of the now useless balance.
I also struggle to see the oil in the jewel. Not sure if it's a combination of not enough magnification or bad light. I am also colour blind so might struggle to differentiate the oil from the colour of the jewel. Maybe I need to get the fluorescent 9010
I use a nylon bristle from a fine paint brush , glued into pegwood x3 different diameters. The thinnest  just fits through a 0.7mm jewel hole . Also use it to grease pallet stones.
6 hours ago, Simeon said:
. I also struggle to see the oil in the jewel. Not sure if it's a combination of not enough magnification or bad light. I am also colour blind so might struggle to differentiate the oil from the colour of the jewel. Maybe I need to get the fluorescent 9010
It can be difficult to see the oil circle. I use a microscope with bright light, and tilt the movement until I can see the oil. I imagine it would be hard without a microscope.
I'd be interested to hear from anyone using fluorescent 9010 - how well does it show up through the jewel?
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
