Little Schatz 8 day clock
Michael1962
Just found this. Hairspring has been destroyed and I don’t know if you can get another one? It would be s miracle if the hairspring could be reshaped. Small plastic dome which used to lock to the base, but the part of the dome that locked to the base has been broken on both sides of the dome
 Worth $10?
3AFF897D-6185-448D-80D8-33BBA8075377.thumb.jpeg.e6ad552393c5929e371eed536a66107f.jpeg8805B6F6-ECDD-4ED0-BB81-01AF2ABCAFB5.thumb.jpeg.0ecdf5939444e4c066990fc079c0b8c2.jpeg
The main problem you have is postage, they are about £30 second hand here in the UK and in much better condition. From experience you will need a lathe to sharpen the balance pivots as they are conical which are jeweled each end. The other problem you have with these movements is where I have marked in red, the springs are very strong and this wheel takes all the main force of the spring and the pivots wear so again a lathe is needed to address the pivot and to rebush.  With no hairspring I would forget it.
