TKM3RD Posted August 20, 2024 Posted August 20, 2024 Hi there. My current project is the overhaul of what I believe to be an A. Schild 1250 bumper movement. It looks very similar at any rate. While in the disassembly process, I took off the rotor (fig 1), and then the automatic winding bridge. This revealed some wheels and what appeared to be a piece of hair. I tugged the "hair" and parts went flying. Turns out it was a spring attached to a pawl for the winding wheel. I put the bits back where I thought they should go and took a picture (fig 2). I finished breaking everything down, cleaned the parts and am ready for reassembly. Though it will be one of the final stages, I am really stressing out because I have absolutely no idea how the pawl and spring should fit. I guess I'll have to wait and see if I can figure it out, but in the meantime, if anyone has experience with this movement, any help would be appreciated. Quote
AndyGSi Posted August 20, 2024 Posted August 20, 2024 (edited) Don't think it's an AS1250. Are there no markings on the dial side? Edited August 20, 2024 by AndyGSi Quote
rjenkinsgb Posted August 20, 2024 Posted August 20, 2024 It appears to be an AS1171; rather different from the AS1250. https://www.emmywatch.com/db/movement/a_schild--1171/ Those appear to have been quite widely used rebranded, I found such as Rima and Rensie / A Raymond branded ones while trying to trace it. If the click and spring are the same as the base movement, this shows the assembly: Quote
TKM3RD Posted August 20, 2024 Author Posted August 20, 2024 (edited) 19 minutes ago, rjenkinsgb said: It appears to be an AS1171; rather different from the AS1250. https://www.emmywatch.com/db/movement/a_schild--1171/ Those appear to have been quite widely used rebranded, I found such as Rima and Rensie / A Raymond branded ones while trying to trace it. If the click and spring are the same as the base movement, this shows the assembly: Quite right you are about the caliber number, thank you. At least I was in the ballpark It is branded and cased as an Easton "Quadramatic" militrayesque watch. It's quite pretty. Anyway, I'll have to review the video when I get off work. Thank you for the assistance! Edited August 20, 2024 by TKM3RD additional information Quote
AndyGSi Posted August 20, 2024 Posted August 20, 2024 (edited) This forum post will probably give you a better idea what goes where. Edit This here is a lot clearer. https://watchguy.co.uk/cgi-bin/library?action=show_photos&wat_id=3006 Edited August 20, 2024 by AndyGSi 1 1 Quote
TKM3RD Posted August 21, 2024 Author Posted August 21, 2024 Well, thanks to all the help. I got it together without drama, although it is running like a two legged cat in a mousetrap factory. Tick-tick-tick---tick-tick-tick-tick-tick---tick-tick and so on. Rate=+570, AMP=317, BE not picking up. Sure is a pretty little thing though! Thank you all again. Quote
AndyGSi Posted August 21, 2024 Posted August 21, 2024 I presume you've got it on Auto as the frequency should be 18,000. Can't see what you had the lift angle set too but it should be 52 Deg. 1 Quote
Nucejoe Posted August 21, 2024 Posted August 21, 2024 I concur with AndyGSI, Frequency is 18000 , your tg shows 19800. I bet you haven't replaced the mainspring. AND always dispower the movement through the click, before starting disassembly, to prevent parts from flying, damage to the pallets face and escape teeth ,...etc. Good luck. Quote
TKM3RD Posted August 21, 2024 Author Posted August 21, 2024 19 minutes ago, Nucejoe said: I concur with AndyGSI, Frequency is 18000 , your tg shows 19800. I bet you haven't replaced the mainspring. AND always dispower the movement through the click, before starting disassembly, to prevent parts from flying, damage to the pallets face and escape teeth ,...etc. Good luck. @Nucejoe, nope, didn't replace the mainspring. I always release the power, and generally the first thing put into safekeeping - after the dial and hands - is the balance assembly. Thanks for the reminder though I'll have to check the Timegrapher settings. Oh, there is no luck involved: I either do it right or I screw it up. S-l-o-w-l-y getting to the 60-40 mark. Thanks again! Quote
TKM3RD Posted August 22, 2024 Author Posted August 22, 2024 Ah-ha! Eureka!! I couldn't let it go. I took the balance assembly off and really looked carefully at the hairspring. Lo and behold, there was a very, very, fine thread tangled in the coils. It was buggering up everything. Got it out, cleaned and oiled the upper and lower jewels, got it back together, and just like that, the snow storm on the TG stopped! I had a good trace, albeit a fast one, but it's settling in for a day or two, and then I'll regulate it. Overall, I'm happy. 2 Quote
