Threaded Clock Key
dnhb
My neice's no-name clock movement needs a reverse threaded winding key. Would I be right in thinking that it would be best to make one - involving the investment in an appropriately-sized Tap - rather than trying to find one to fit?
Edited by dnhb
To add photo
Thanks: yes I'd seen these but there didn't seem to be one of the size (I think) it needs & £20+ seemed a lot to shell out in the hope I do get one that's suitable (I know returns are accepted but I don't really want the hassle of that). In addition, buying a tool always seems to me a worthwhile expenditure....
Do you know what size and pitch reverse tap you'd need and how much one would cost?
On 9/5/2024 at 9:36 AM, Dell said:
Did you find a key because I may have one, is it left hand thread ?
Dell
Yes it's a left hand thread with an outer diameter of ~3.5mm & an inner (assumed to be equal to that of the top 2.5mm before the thread starts) of ~2.6mm. The thread pitch is ~ 0.75mm. The 2.5mm between the bottom of the thread & the back plate is ~4.5mm diameter. My engineering friend says the pitch looks to him to be relatively coarse & thinks it might be a Whitworth. Thanks for your interest....
On 9/5/2024 at 10:41 AM, oldhippy said:
It looks like one of those old 2 inch movements. Have you tried any suppliers?
The diameter of the back plate is actually 9cms/2.75" but I can't find any markings anywhere on the movement. I have looked online but without success due to insufficient details in descriptions. Also, I rather fancy using this as a learning opportunity re the selection & use of Taps etc as my engineering knowledge is minimal.
Looks as if all you can get these days are those horrid quartz movements
The thread dimensions could be 4BA ?? You can get left hand thread BA taps.
3.6mm outer thread diameter, 2.8mm core diameter, 0.66mm pitch. You could try a 4BA screw & see if the threads fit the side of the winding shaft?
Alternatively, M3.5, though I don't think that's all that likely in old items?
3.5mm, 2.85mm, 0.60mm.
The dimensions given don't appear to match Whitworth or BSF, in the tabled I've found.
Thanks very much indeed. I'll certainly follow up your helpful suggestions, starting with getting a 4BA screw...
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
