I've been working on an Elgin 823 movement and now I know a bunch of reasons why I should've started with a working movement for my first watch. I've launched many pieces and I've found things rusted into place (balance arbor on one movement and the pallet fork bridge screw on the other) and have spent many times what I bought the watch and sacrificial movement for on replacement parts for things that I've launched into space.
But back to my question: is there some trick to getting the tri-lobed balance spring installed back into the movement? I've spent all afternoon chasing the springs as they go pinging across my desk only to lose them eventually. Now that I've cracked the last one I have, I'm thinking there must be some trick other than just practice. Or is it just practice? I can't seem to get them back in unless I forget to put the cap jewel in.
One last complaint for now: I wish someone would've told me how screws (on the pallet fork bridge in my case) can be so rusted into place that I could ruin the tips of my Bergeon screwdrivers. I think I fixed the tips with my sharpening stone. I have to stop watching videos of people who only post their successes, which is EVERYONE who posts a video.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
