On ‎10‎/‎2‎/‎2019 at 3:00 PM, yankeedog said:
When it  comes to buying cheap tools,I am like a dog chasing a skunk..I never  learn.
     when it comes to "horse play"  in the machine shop;  I am a veteran !  think "oxy acetelene"   and spark plugs.  vin
  • 1 year later...
Time to revive this topic.  Precise system conversion is important! Imagine the difference 2 tenths of a mm could make in a brush!
I had a credit with a shop form when I bought some braking grease for some binoculars that I was restoring. Somehow I ended up with 2 on the order. When I paid for it I realised the mistake.. They would not refund me the money for the second tube, just gave me a store credit. Just got a Pin Vise from them today. Made in India, not China. Go figure. Anyway, the revolving end, much like those cheap 'precision' screwdrivers that you can buy, is actually on a bearing. The knurling on it is really good. The collets, there are two double ended ones, are quite good as well. I am really quite surprised to tell the truth.
Reminds me of a recent visit from our local plumber. I had attempted to unblock the bath drain with caustic soda, which was a complete failure. As a result I now had a solid lump of caustic soda, old hair and calcium in the U-bend.
The plumber, who I know quite well arrived with a plumbers grade fix for the problem in the form of sulphuric acid.
We poured in a tiny amount and there was an interesting explosion. Rather than do the obvious and desist from continuing this potentially disastrous line of repair, we agreed the best course of action would be to remove the entire blocked U bend and continue the experiment outside in the adjacent barn.
Safely away from more sensible adults, in said barn,  more acid was added, and a fountain of interesting highly caustic brown goop ejected itself violently from the poor unfortunate plumbing piece. Naturally we tried again with similar results and much amusement from two individuals who should know better. In the end we just replaced the U bend, as for some strange reason it had cracked.   Do not try this at home children.
Edited by AndyHull
  • Haha 4
Post a picture? India has a good tradition in tool making. For watchmaking their Anchor brand is the South Asia equivalent of Bergeon, distributing a wide range of tools. I have various and all are worth their low price, just some adjustment is necessary sometime. Often they come with beautiful wooden boxes making the purchase worth for that only. Cousins UK carries a wide range, your pin vises could be from them.
If you get serious about machining (not necessarily a good idea) check out out Soba tools and Zither chucks. Chronos.ltd.uk and arceurotrade.co.uk carry these, I have some, want more, and nothing to complain about.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
