I have that set Rich, I have randomly gone through about 20 of the guages and they have all measured correctly using the Feintaster. Don’t put the smaller ones down on your bench, they make click springs look big and thick 😂
Tom
6 hours ago, AndyGSi said:
What's the delivery charge on them as I've got this set in my basket for ordering later this week.
Was going to order them this weekend but thanks to @Neverenoughwatches and Flume I've just spent £50.00 on books.
Sorry about that Andy, i didnt pay a lot for the Flue catalog i have. I could have scanned the book and sent you the pages.  The pin gauges were 45 quid in total inc. Shipping and tax, i think the shipping was around 12 quid. I got the 0.1 - 1mm in 10 micron increments.
Tom
Thanks Tom, I'm sure Jon also said his were accurate.
Not sure if it's the same Flume book that you've got but the one I've order is the Band 4 with a green cover and cost £15.00?
But I then also saw a Flume K4 Quartz book and another for French movements hence the £50.00.
Can you send me the link to the pin gauges as yours works out a bit cheaper than the one I was looking at.
Red cover Band 2/3 the caliber listing is easier to handle than bestfit, choose the pallet design, then holes per set lever then the size. I'll get that link.
https://www.aliexpress.com/item/1005003664177054.html?spm=a2g0n.order_detail.order_detail_item.3.3eb7f19cQtqUzy
I knew I should have asked first or done more research as the Band 4 is for clocks, Doh!!!!
Well maybe this is the next step in evolution.
Haha not a complete waste Andy the same flume book i have sold for 20 quid or so last week also the swiss catalogs. I'll see whats involved with scanning them and possibly post a download if someone can talk me through it. I wonder what copyright laws exist with them. Did i say scan and download them ? I meant copy every detail in their entirety and post a simple link for all to take advantage of the situation and completely ignore any copyright that forbids such action 🤣🤣
I bought the 0.5 to 1 mm set, as well as the 1 mm to 2 mm and the 2 mm to 3 mm set. The bigger pin gauges are great for barrel arbor holes in mainplates and barrel bridge when boring to create an even hole from an ovaled one before bushing. They are mentally accurate, as my JKA Feintatser tells me.
I bought all my sets from these guys https://www.aliexpress.com/item/1005005362640246.html?spm=a2g0o.order_list.order_list_main.246.44ba1802PTiHEm
I have my Bergeon pin gauge set for the small stuff. 0.07 to 0.5 mm
Good price for this set. The expense starts at the really small sizes
So true. I bought my Bergeon gauges for about £300 to £400 a couple of years back, but I'm glad I did. I've used them a lot. Great to show the taster day students as well.
On 9/2/2024 at 6:55 PM, Jon said:
I couldnt find a set starting at 10 microns for under 40 quid inc. Tax and shipping. But the ones over 1mm are good value, shame Ali dont combine shipping costs, each and every item has it tagged on.
You need to look for the Choice which gives free shipping over £8.00
https://www.aliexpress.com/item/1005002641872231.html?spm=a2g0o.productlist.main.11.2c32nw0anw0aEo&algo_pvid=e65a020e-9fbc-4f36-910e-0d6b0bea8def&algo_exp_id=e65a020e-9fbc-4f36-910e-0d6b0bea8def-5&pdp_npi=4%40dis!GBP!24.39!24.39!!!31.05!31.05!%402103868d17254426832712454e35e6!12000021524620758!sea!UK!2273346395!X&curPageLogUid=rjonXxZdHOTq&utparam-url=scene%3Asearch|query_from%3A
1 hour ago, AndyGSi said:
Not sure if they bump up the item price to compensate for the free ship Andy. I have these in my basket works out about the same, i dont think they discount ship costs for multiple purchases.
There probably isn't must difference in price, maybe a few pounds here and their, but with the Choice you
get guaranteed 5 or 7 day deliver where a lot of the items I've been looking at were showing 2 to 3 weeks.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
