Hi everyone and thank you for accepting me. I'm a teacher and recently got into watches, I'm about to turn 50 and treated myself to a nice watch. I got a Momentum Torpedo Pro Eclipse - Solar [44mm]. But it stops working whenever I wear it!! Take it off and set it down, works fine, put it on stops after 15-30mins????? Momentum sent me a replacement but I'm curious why this would be. Any ideas?
There are a few people that have static in there body all the time. I'm not saying this will put it right for all but a small round plaster stuck on the back of the watch, so between you and the watch no direct contact sometimes works. So give it a go and let us know.
Hi and welcome to the WRT forum.
 We all are Mr STATIC,  Oops I sure hope your students don't read this . 😂 lol
 As we walk specially if one drags his foot on the ground/ carpet..... etc . We collect static electricity in the capacitor our body is, as our body  contains many  elements which charge no $ fee to host charged electrons.
Rgds
I've heard about this before, I dont think it was static related though, something else going on in the body. I was permanently static charged as a kid, my dad constantly getting me in a headlock and rubbing his knuckles on my head 🤨.
I'm one of those. I have an extremely low skin resistance and at those funfair strength testers where you grip two metal rods to test your "strength", all I have to do is lay one finger on each rod and the meter goes off the scale, the lights and alarms all go off.
I recently changed a new pair of sneakers and the insulation must be really good because I store up a charge very quickly and touching anything that is grounded will give me a slight tingle. And this is in Singapore, where it's so humid that static electricity hardly ever builds up.
But coming back to the watch, I don't think static electricity can affect the electronics as the metal watch case acts as a shield.
The possible explanations I can think of for the puzzling problem is
1) Temperature - it could be your body heat is causing a bad solder joint or contact point open the circuit. You test this by heating up your watch in an oven or with a hairdryer.
2) Movement - it could be a loose contact that opens when jarred around.
3) Gravity - it could be a loose contact that comes open when the watch is no flat on its back.
Thank you everyone. If the cause was static wouldn't that effect other watches? I've never encountered this before.
HectorLooi's 3 reasons sound plausible. Sounds like it would be repairable.
Many thanks
