Schatz Elexacta Carriage Clock
HectorLooi
I received this electromechanical carriage clock this afternoon. It's a Schatz Elexacta. The seller described it as "balance swings freely but doesn't work, nonetheless a nice piece to display".
I thought the four panals would be glass but it turns out to be plastic. Externally, it doesn't look too bad.
But once the cover is off, the true extent of the damage is evident.
There must have been a massive battery leak. A lot of the brass is corroded and some pivots have rusted away. Some of the pinions have also rusted.
The winding mechanism is a little strange. Instead of a DC electric motor, it uses a modified DC relay which when activated, kicks a weight which will wind the mainspring. The mainspring is so small and fragile that some of my other clocks have hairsprings that are beefier that it.
Looks like this project would be more involved than I expected. I'll need to repivot two wheels and straighten one pivot. Clean off all the rust and polish the brass. Then apply lacquer to preserve the brass. It's probably going to take me a month or two to complete this.
  • Sad 1
5 minutes ago, Dell said:
The pivot on the right hand mobile looks bent
Yes, it quite obvious, isn't it. That's the one I intend to try straightening. If it breaks, then I've to repivot another one.
I still trying to dissolve the rusted pivots out of two holes. Managed to loosen one already. The other one is completely rusted, not a bit of steel left. I might have to drill it out and rebush that hole.
I'm curious as how these plates were finished. Are they plain, polished brass and varnished over or are they gold plated?
This piece I'm working on seems to have some shiny bits. I tried softening it in paint thinner but nothing happened.
I would have said lacquered brass ( is it magnetic) because it may be brass plated steel , if brass then you can soak it in a very concentrated solution of alum it will not touch brass but will dissolve steel over a few days.
10 hours ago, HectorLooi said:
So, if Horolene removes lacquer, does that mean that the brass plates have to be re-lacquered everytime they are cleaned?
That all depends on the repairer. If the clock came to me and it needed a complete O/H it would certainly get the full works.
I have been cleaning and polishing the brass plates the last two days. The battery juice has caused dezincfication of the brass leaving patches of porous copper. I might have to dig my polishing lathe out of storage to buff out the damage.
I have a question about the prep work prior to to applying lacquer. What material would be suitable to plug the pivot holes to prevent lacquer from getting into holes?
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
