Zenith stops when engaging the calendar
AxelSLK
Heyo!
Once again I turn to you kind knowledgeable people for help.
i have been battling a zenith 2542pc for a few months now. Some of the issues I have battled so far is broken screws, lost click spring, broken incabloc spring, loose automatic rotor and now I have issues with the calendar works. (Some of the issues is my own doing hehe)
To the point. Fully serviced the movement to the best of my knowledge (keeping the old mainspring), got it on the time grapher and it seems to be running fine after some adjustment. Generally about 260 degrees amplitude in both DU and DD but I noticed that the watch stopped around 9pm with a lot of power left (enough to make it through the night). I could either shake it so it kicked back up or I could turn the watch forward a bit and it immediately kicks back up.
 I took it apart again to check the calendar wheels but I couldn’t see any damage or dirt that could make the watch stop at a specific time. Put a bit of HP-1300 on the yoke where the calendar jumper mechanism “whatever it is called” touches. Cleaned the wheels put it together. Put the watch on the timegrapher and it works great when the calendar is not engaged but as soon as the time gets closer to 17pm it drops the amplitude to about 220-230 and it doesn’t keep the time as good as when the calendar work is not engaging. When the watch isn’t fully wound it even stops every 30min to 1h.
Do anyone know how I properly lubricate the calendar works?
Do I need to replace the mainspring?
Could it be something wrong with the gears or something else that creates this issue?
I have noticed that the winding gets a tiny bit heavier when it gets close to 6-7pm when the calendar works engages but I didn’t really think of it until I realized it was an actual issue.
What do you think?
2 hours ago, nevenbekriev said:
Hi Axel,
Something makes me thing it has nothing to do with the calendar. To be sure, remove one of the calendar wheels and try without it
Hmm you might be very right my friend. Unfortunately I think I will have to completely take it apart again and see if I can find anything.
any suggestions on what to look for? Or any suggestions when putting it back together again and how to oil the calendar system?
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
