Hi,
I want to buy a starting tools such as loupe, tweezers, movement holder. pad etc. and I see that Aliexpress has all I need but I always sused that those are chinese replicas although they look exactly like the real thing, for example:
https://www.aliexpress.com/item/1005005099022972.html
https://www.aliexpress.com/item/1005005742598746.html
https://www.aliexpress.com/item/1005005108369510.html
https://www.aliexpress.com/item/1005006391855291.html
can I count on the site credibility that those products are original? I know that Amazon is an option but shipping is way more expensive since I'm not located in US nor EU.
Thanks!
Welcome to the forum.
First thing is if you're just starting out with watch repairs then I wouldn't start off with expensive tools like Bergeon.
Personally I wouldn't trust anything that's branded from AliExpress when there are genuine suppliers where prices don't appear much different.
https://www.julesborel.com/products/tools-tweezers-bergeon-tweezers/bergeon-7422-pm-b5-tweezer-brass-non-magnetic-alloy
https://www.julesborel.com/products/tools-movement-tools-movement-holders/bergeon-4039-movement-holder-3-3-4-11-ligne
https://www.julesborel.com/products/tools-movement-tools-movement-holders?search=2611-tn-2.5
https://www.julesborel.com/products/tools-bench-accessories-bench-mats/BG6808-GREEN
The Chinese are masters at counterfeiting. Stick with someone stateside so if you have any questions, you can call and talk to someone.
Esslinger.com is another decent place to buy tools. Pretty good prices and their service is great.
I rarely buy new tools now , mostly vintage secondhand tools bought from carboot sales , ebay or auction houses.  The older stuff is so much better quality than anything bought new.and often cheaper. For example i have just bought 5 pair of Dumont tweezer ( ok not vintage but i did say mostly 😆 ) 3 of these are duostar and dumoxel , a really unusual ruby jaws poising tool, brass pocketwatch movement holder, and handful of lathe accessories and a rack of 12 arbor vices for 150 quid inc delivery. It takes time to build your workshop in this manner and some restoration can be needed but thats part and parcel of this game, the upside is the cost and excellent traditional quality tools that were designed with the user in mind and they work as they are supposed to instead of a modern chinese manufacturer guessing what they are supposed to do. Other than that making what you need, bench mats, cushions, probes , tool holders, hand tools,  parts washers, have a look at our tips and tricks, diy and homemade threads. A little inspired ingenuity can go a long way to saving you a lot of dosh plus you get to make something custom that is suited to you and how you work. This hobby doesn't have to be super expensive, only if you let it 🙂
If you live in Europe for example the UK, Monaco, Moldova, or Norway, I'd suggest CousinsUK.com. That's where I go whenever I buy new stuff. Good prices.
As you are new to this I suggest you go slowly before making a substantial investment. Start with a decent...
  • work mat,
  • case holder,
  • case opener,
  • movement holder,
  • screwdriver set,
  • tweezers,
  • hand levers,
  • hand-fitting tool,
  • cannon pinion remover tool (perhaps not necessary)
Now you can take apart and reassemble a watch to get a good feel for it. I don't think I missed anything essential but if so others will fill in.
Edited by VWatchie
I forgot to mention that some sort of magnification is needed when you get started. In the beginning I only used magnifying glasses and I still do but now I have loups and a stereo microscope to complement.
Here's a post I wrote about it when I had just started:
https://www.watchuseek.com/threads/would-this-stereo-microscope-help-me-do-the-job.4468922/?post_id=43623827#post-43623827
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
