JLC Cal 218 M cannot stop alarm
quantieme
Good afternoon all, as the title says I have this 2 day travel alarm but cannot seem to stop the alarm. The button is just held on by a circlip and when the alarm  rings you can press it and the alarm will stop but as soon as you let go it carries on ringing. There does not seem to be anything to hold down the alarm stop lever, this lever is screwed to the plate and has a tension washer between the lever and the screw head and there seems to be no happy medium in being able to tension it enough, too much stops the lever completely and also it works loose anyway. Is it meant to be like this as in just designed to make you get up or is there something missing. I did try fitting a spring which was quite strong and held the lever down but it was not strong enough to work as a stop when it rang. Anyone have any ideas. Thanks Tony
