13 hours ago, AndyGSi said:
If you have the experience to be working on one of these then you shouldn't need any documents.
that's an interesting comment? For those that don't grasp what this watch is which was me up until a few seconds ago I have a link.
On 9/11/2024 at 8:19 PM, bjoe9 said:
p.3000?
this is a watch repair discussion group I don't suppose you have pictures? We love pictures of watches that people are going to or are thinking of servicing.
https://watchbase.com/panerai/caliber/p-3000
they have a interesting website and the cost of this watch is interesting? I assume because you're inquiring you must have one then yes we really love pictures the movement and will love pictures as you disassemble. Pictures are also handy when it comes time to reassemble. Then looking at the website looks like they make most of their own parts and they do offer servicing which means they probably do not sell spare parts. Then typically with in-house movements nobody has spare parts at all. Which means servicing becomes extremely problematic if you cannot replace any of the components at all including more than likely the mainspring.
https://www.panerai.com/en/movements/hand-wound/pnmx00879w.html
then typically service manuals only exist if the manufacturer wants people to service their watch. Which typically only be in the old days because currently I don't think anyone wants us servicing their watch. which brings up the challenge today of purchasing spare parts if the watch companies don't want to sell us their spare parts.
this is the watch in question. yes. i plan on wanting to service this but wanted to see if anyone would have any service docs before i do so. I've worked on their OP XI already but that's just a basic 6497.
this is not in any way to sound harsh or dismissive, but this does look like a fairly straightforward movement, minus whatever that little crescent shaped cutout is to the left of the balance. No date, no automatic works. Looks easy enough, but its not my watch so I have no idea.
According to this, it has two mainspring barrels
Edited by SwissSeiko
it's so it can have three days of running.
what’s the likelihood anyone has service documents for the p.3000?
if they wanted the world to service their watch and this watch is been out for nine years it seems like the technical documents spare parts availability should exist maybe you should email and ask them? In the meantime who needs technical document if you have a video of how to reassemble it. and lubrication should be pretty straightforward it doesn't look like anything complicated there.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
