Felsa 1560 - movement issue.
Hello again..
I just serviced this movement. First ever movement to service.
I had it running pretty good (before regulated it) yesterday (see attached photo)
But of cause I forgot to put in the screw that secure the winding stem in place.. it’s placed under the bridge, and that bridge is a pain in the a$£ to set in. I took it apart again, and after reassembly it runs bad. It’s like it doesn’t take my winding.
When I take the little metal piece (photo attached) that hold the mainspring winded, nothing happens. So I guess that’s a sign of maybe a bad mainspring? Only the upper wheel on the mainspring barrel is turning when winding, is that right? (Also photo attached)
Watch is cleaned by hand in IPA and oiled.
10 minutes ago, Nucejoe said:
Check if ratchet wheel rubs on barrel bridge.
Possible cause,
Ratchet wheel's centre square hole ,dislodged from barrel arbour square shoulder.
Så both should spin? While winding? This rachet wheel is a bit different than what else I’ve seen.
First image- Ratchet wheel's center hole is square.
Second image-Barrel arbour square shoulder too.
In your watch ratchet wheel has jumped out of place, therefor ratchet wheel has sat unlevel, thus ratchet  wheel rubs on barrel bridge.
Edited by Nucejoe
Adding explanation
13 minutes ago, Nucejoe said:
1- Ratchet wheel's center hole is square.
2-Barrel arbour square shoulder too, is square.
Should fit on right.
In your watch ratchet wheel has jumped out of place, therefor ratchet wheel has sat unlevel, thus the wheel rubs on barrel bridge.
It looks similar to this one. Is it still the same principal?
Also recognized that the hair spring looks a bit odd?
Yes its the same principle.
Design of the hole in your watch,  is proof of the designers over excitement.
Above diag of mine is solid.
What do you find odd about it?
 Its not  an overcoil ,  Is it ?
 As long as the coil of hairspring is flat, concentric,  level and circles are evenly spaced, you have a good coil.
You didn't choose an easy one to work on, but thats OK.
3 hours ago, apandersP said:
Hello again..
Do you have the auto works for this movement ?
Yes. But that’s a whole other story. It seems like the mechanism that attaches it to the movement, is not working. It kind of a spring with a small lever to push down.
Will get some better photos when I get home to the watch again. Just to be sure that it’s okay. Because that bridge for the train
of wheels is a pain to get back. And the mainspring barrel is under there😂
it’s not an easy movement, I found out of that working on it. Actually I don’t think it’s too hard, but I definitely need a lot more experience with trouble shooting and stuff like that. I was so happy when I’ve got that Timegrapher reading after servicing the watch. It was a total mess before I got into the watch. First watch serviced, so I was happy. But that happiness fast got away😂
What you have here is an interesting historical watch, the first two directional rotor automatic wind movement, known as the Bidynator. Be good to get this back up to working and keeping time.
I’m trying the best I can. I will show more info and photos when I get back home, and hopefully I can find the issue, with help from the good people here
4 minutes ago, apandersP said:
Seems like anything is good. It might be me damaging the hairspring…
I guess that’s how I learn😂
 Sorting out hairspring in place is not a good idea if your a beginner. Removing the balance complete ( if you feel confident) gives you a chance to see the coil, check pivots and make sure all is OK.
Provide a side and top view of the hairspring coil, we might see faults that you now miss, and show you how to correct it.
Felsa made good movements, this is the first stupid design of theirs I ever saw.
Had it been a standard ratchet wheel, your watch would be ticking now.
No worry, take your time , ask questions and let us work with you to fix your watch.
Best wishes.
59 minutes ago, rehajm said:
In situ the coils do not appear centered. Let’s see more pictures, preferably in and out of the watch if possible…
I can definitely take it out and take photos. Will do that Sunday. I had this movement completely apart for cleaning and lubrication. So that’s no problem taking out the balance.
i will post it here when it’s done
Here is some photos. Please let me know if anything else is needed.
Best wishes.
thanks so much! I posted some photos
Are you saying the arbor hook comes out of the mainspring eye shortly after starting to wind ?
I think that’s the case. It also feels like it, when I got the barrel complete in my hand, and trying to wind the upper wheel. It feels like it grabs it in the start, but quickly stops grabbing again.
47 minutes ago, AndyGSi said:
The problem with these is the arbor is part of the lid so you can't see how it interacts with the spring.
I've delt with a few that had the arbor integrated into the lid, from memory were Kienzle and Kasper so German movements. The ratchet may also have formed part of the whole assembly, not an impressive design, somewhat all wonkyfied. But yes a bit difficult to see whats going on inside in barrel .
Yes, lid, ratchet and arbor are all one piece.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
