I would like to screw some movement screws into a block in order to work on their heads.... and also I would like a block to be able to test screw sizes and thread sizes...
Does such a thing exist?
I have one of these:
Edited by JeremyLaurenson
Added detail
I think you'll find there are too many sizes and pitches of thread across different brands for it to be possible.
I've been considering one of these that may work to hold screws but would probably make some plastic jaws.
You could try putting rodico in the holes but not sure if this would hold the screws well enough.
Usually one can use the main plate of the movement without the bridges for this purpose. Or the main plate from some useless movement with the same thread size of the screws.
The best results gives working on 3 screws together at a time. As a plain is determined by 3 points.
Edited by nevenbekriev
I like working with polishing sets like the one discribed in this topic.
They come with a selection of brass collets (soft..) to hold the screws so you can work on the heads. Often, they also contain special holders to enable work on the threads and even the tips (of one's OCD gets into overdrive..).
Edited by caseback
Similar to @caseback my suggestion would to be make a simple screw polishing tripod and it can be used as a screw vice as well as flattening/black polishing screw heads.
here is one such thread which should help.
Tom
    • Agreed, this is puzzling. Can you ask questions or inspect the lots before bidding? My Boley & Leinen Reform face plate is dia. 95mm exactly. It's possible that 4 inches is a slightly too large approximation, but why then make the distinction to 3 11/16 for the sake of 8mm? If the larger ones are truly 4" then they will clash with the bed, but then I have no idea which 8mm lathe would take them. All 8mm lathes have spindle height 50mm or less, as far as I know. The spindle height is, as you say, standard 50mm for W.W.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
    • A local machinery auction this week is liquidating some watchmaker's equipment. Actually a truly absurd amount of it, from a machine collector's estate, making me wish I had waited a couple of months to buy my lathe because there are so many options at low prices. Anyway - there are a handful of faceplates on 8mm collet mounts up for sale and I think I can probably get one. Having never had one in hand, they seem kind of large as described though - all are listed at either 4in (101mm) or 3 11/16in (93.7mm) diameter. As I understand it, WW lathes are 50mm from spindle center to bed so it seems like the 4 inch faceplates would not have enough clearance. Could I expect the 3 11/16in to fit with a WW headstock and bed? What is a typical diameter for a faceplate? Also possible the description of "4 inches" is only a rough estimate by the auction house and not actually accurate. Example the 3 11/16": I may have answered part of this - a lot of the listings on ebay from typical American lathe tool makers are specify about 3.75 inch diameters. Still I don't see any that specify 4 inches, but I am still guessing that is an overestimate by the auction broker.
    • Buying a specific jewel for a specific movement is difficult if not impossible in most cases. cousinsuk/jewels
