Hello All,
I am looking for the following screws in gold colour,
Dimensions in millimetres
Head diameter
0.83 - 0.84
Thread Size
0.47 - 0.48
Length
1.57 - 1.58
I’m thinking of these ones Diagram 101 and 127
cousinsuk.com/product/bridge-screws-wristwatch-graded#
cousinsuk.com/product/balance-screws-wristwatch-graded
But I can’t find their thread and length other than reference to ‘diagram’
I would appreciate if someone advise/point me finding/buying them.
Thanks
Movement
ETA 201.001
Calibre
9.9mm
SCREW, CELL CLAMP #
X/12142 (54400/201.001)
I found these two suppliers so far,
http://www.julesborel.com/checkout-2-05-0/cart.ssp?sc=3#cart
https://hovigs.com/products/battery-clamp-screw-x-12142
The estimate total cost for 5pcs is ~ €70 including shipping import tax EU
I would rather buy within Europe to cut shipping/tax expenses. Cousinsuk indicates it’s discontinued.
Edited by SAMyMAS
The part you've shown is a Ronda 726 screw. If you've searched 54400 then that's just the generic part no. for battery clamp screws.
The 51.600.01 is used across multiple ETA movements. (example 210.001)
I have checked part numbers in ‘Swiss part description’. Am I right assuming they are interchangeable to the subject one - same dimensions and colour?
If that’s so, than I found better price for ~£2.
12 minutes ago, SAMyMAS said:
Thank you Andy for the wise observation. I learn now that the movement/calibre ought match part number.
As mentioned earlier, sometimes the calibre can be different as a lot of parts are
used across them but the key part is the manufacturer which in your case is ETA.
  • 5 months later...
On 9/15/2024 at 8:39 AM, SAMyMAS said:
Thank you Tom for the confirmation. I will go for 3 pack. Thank you Andy for the wise observation. I learn now that the movement/calibre ought match part number.
Hello Samy i hope everything is well on your end. I too am looking for the same exact screw that I saw you posted about me too for a chopard watch. Could you please let me know if you were succesful in finding one where you ordered it from and how fast the delivery was. Any advice or help in this matter is welcome. Thank you so much for your help
  • 4 weeks later...
Hello @Tahagg
The identical screw is: SKU X/12142, 0 54400 / 201.001
I bought similar ones from cousins.uk: ETA21000154400, ETA 210.001 54400 as kindly suggested by @AndyGSi, but notice they are silver colour not yellow/golden, other than that I think they should fit, but I didn’t try. The delivery in EU is within 10 days.
I bought the identical screws - yellow/golden from US, hovigs.com *****@*****.tld. They’re are very nice to deal with.
Edited by SAMyMAS
Additional info
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
