Hi all,
This may be a silly question but I haven't seen it addressed before.  I have an old Vostok 2809 which could use a new balance jewel,  not the capstone.  I'm really terrible at finding parts, but someone from Ebay suggested I could just remove the hole jewel from the setting and replace it easily.  Is that possible, or am I better off finding better places to shop?
I'm not even sure if this is a real Incabloc setting or a Russian "homage."  If so, I'd also love to buy a dozen replacements for the springs, for um, reasons.
The jewel the brass ring is 1.4mm wide and pivot diameter 0.3mm.
Thanks!
Edited by NigelTufnel
Changing the chaton jewel?  I've never tried it, not sure how you would get the jewel out without damage.  Might be easier to try to find if the parts on common on cheaper movements, then look for one of those for parts.
Imagining they use a jewel size that corresponds to standard replacement sizes (on diameter and hole), there's still the issue of the jewel height. In a shock setting that would be strictly controlled, to provide the proper gap with the cap jewel. Jewels aren't made to a fixed standard, and a few hundredths difference of height could be make-or-break. That's aside from the issue of of pressing out the old one and in the new one without damaging the setting.
I would suggest that you try to find some donor movements on eBay. Often these Vostok movements can be had for very little money and in the process you get spare parts for future use.
Before the war in Ukraine, there were many Russian sellers of these movements, but as of the war, they have disappeared. I guess Russian watch collectors are evil people. Anyway, still a lot of Ukrainians selling these movements, but they are in my experience a lot more deceitful than the Russians used to be so be observant!
Edited by VWatchie
On some old pieces that use an uncommon shock setting, I have converted them to Incabloc. I know it's best not to alter things, but I always managed to get one in without having to ream the plate or something (sometimes requires turning up a thin bushing though). So if down the road it's discovered that it's some sort of museum piece, it could be brought back to originality 😉.
You find the pivot sizes are usually compatible too, or do those ever need modification?
For a given Inca reference, there are several hole jewel sizes available. So supposing you find in your stock of parts a "bloc" that would be a good fit, but the hole jewel is over/undersize, you can get or find another that would be correct.
Inca's website has lots of useful into. "Sus" means upper, "sous" is lower; if you look at the different models on their site the refs end in /0. In practice you add -10 for example for a hole size of 0.10mm. I have some here straight from the factory, "sous", 100.935.20.000/0-10. That's a lower bloc, with 0.10mm hole. The odd thing is on their site, this ref is listed as 935.20/0. My guess is the first 100 is the hole size in microns... the rest?
I have some older (like 50 years old) factory packaging where they simply write the hole size before the ref, like 9.104.12.262, where the first number is the hole size. If you know the ref you want, a good supply house will figure it out. All the current models are on the link above.
1 hour ago, VWatchie said:
I'm not sure but the following lot could possibly be worth making a offer if you're looking for spare parts.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2332490.m570.l1313&_nkw=315358235604&_sacat=0
I guess that You have never seen 2809. None of watches in the lot has this movement. Actually, there is not plenty of them.
@NigelTufnel, how did You decide that the hole jewel of the setting is for replacement? Is it broken?
Hey @nevenbekriev - Under a microscope there appears to be a hairline fracture that doesn't quite touch the pivot hole yet.  I have a replacement from a donor, but it's suffering from very odd pitting on the inside face, and salt-like debris which Naptha and IPA have failed to completely remove.  It's much better though.
In the oldest USSR jewels You may see things that look like debris or pitting, but they may be actually in the structure of the stone. What the results from free oscillations test are? Is there noise from the balance pivots rotating in the jewels?
No noise, and the 'cracked' jewel passes the free oscillation test just fine.  I think I'll leave it alone for now and save the donor jewel (pitted) as a spare for now.  Next is the new mainspring which should arrive tomorrow.  I'm super excited.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
