Hello
My heart went "thump" when the Incabloc shock spring I was working on flew. Luckily I found it using a magnet. Now the challenge is to re-install it without it joining the frequent flier program - again! Does anyone one have any tips, tricks or links to a good video that would explain the process? I'd prefer to watch a video as that's how I learn best. Thanks in advance for any help that can be provided.
Spread a nylon sheet over the movement, or put the movement in a ziplock bag.
Edited by Nucejoe
Typo
Hi use a large poly bag with both ends cut off so you can get your hands in each end   Place the watch in the centre and work from both ends, if the clip goes AWOL. It’s captured in the bag.
As suggested use a poly bag over the jewel setting. Genuine incabloc springs are usually contained in the chaton at the hinge. My advice for not losing shock springs is much harsher so i apologise in advance 🙂........get better at removing and replacing them......practice practice practice.....and when you're done practicing.....yes you've guessed it practice some more until you're good enough not to lose them anymore.
Rodico on some wood is useful to hold and move the spring, the rodico has some flex and tends to give before the spring gives.
5 minutes ago, mcoulton said:
Thanks for all the responses. The movement is an Valjoux 7750 clone. The shock spring is Incabloc.
If the movement is clone then the springs usually do come out without removing the chaton.... so not a genuine swiss incabloc jewel setting .
You will find using rodico useful for handling the spring, attach it to a toothpick, pick it up, carry it , place it, i use a fine needle point to click in the tabs of the two sides, after dab the chaton with rodico to pick up any that remains.  Another way is to weakly magnetise the spring itself.
The belief that only Chinese clone shock springs and not genuine Incablocs come loose is a myth.
I worked on a ladies Omega a few months ago and being a genuine Omega, I was a little cavalier when opening the shock springs. The upper jewel was fine but the spring of the bottom jewel took flight when I swung it open.
There was a little gap between the chaton and the main plate and this was how the spring managed to slip out. Had a real hard time getting it back in, as the gap was so small.
So now, regardless of whether it's a clone or genuine Incabloc, I always use a pegwood stick to prevent the spring from getting anywhere near the back of the hinge where it may slip out.
actually I think it's only one half of the myth.
I'm pretty sure the top spring usually on a real one is not coming out but I've had the exact same experience with a different brand of Swiss watch for the bottom. I'm guessing because it's so much then there in the top maybe they changed something but yes I have had them come out the bottom never have come out the top of the Swiss though.
So one half of a myth.
That I was trying to remember of the one I had that was a long time ago whether I was able to sneak it in through the bottom or whether had to take the entire setting just can't quite remember
Hello
I wanted to follow up on the post. I managed to get the shock spring back in placed using the advice given and this video at time mark 6:45. I also made this tool displayed at 2:35.
Thanks for all your help.
Michael
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
