So, finally managed to snag myself a staking set from eBay. It's a vintage Boley and Leinen set and it looks a bit rough - this is OK as I didn't pay a lot of money for it. Some of the punches look like they have been used to drift out truck wheel bearings!
Anyway, I am planning on cleaning up the punches (soak in Evaporust followed by chucking them up in my drill and polish with wire wool and oil) plus working on the ends with an oil stone /Emery cloth to debur and tidy up. I will also make a new lid for the box and repaint the 'anvil' (this is the non-functional part of the restoration, purely for beauty 😉).
Do staking punches come in a common size? 5mm? If so can I buy replacements / new to pad out and complete my set? I had a look on Cousins and they only sold complete sets, not individual punches so I am guessing that I would need to find odd used punches on eBay rather than being able to buy new replacements.
I haven't received the set yet so can't measure the punches but they look a similar diameter to others.
Screenshot_2024-10-06-11-35-37-22_260528048de7f2f358f0056f785be619.thumb.jpg.cbad25e8c73853564bc8680c6a714ad9.jpgScreenshot_2024-10-06-11-35-20-17_260528048de7f2f358f0056f785be619.thumb.jpg.0962e3905218199602156b4c49b15cb1.jpg
4,7mm is a common size and probably yours is that size too. Some new Indian/Chinese punches are 5mm if I remember correctly. Cousins still sell individual punches and they are 4,7mm.
Most popular is 4.7mm stakes, there are also 5mm sets available for some makes and i think a 3.4mm to fit a small framed favourite tool.  You have no stumps with this set though,a stake reversing sub base would be handy in this situation .
Actually, I did wonder about this. The eBay ad describes it as a 'dual anvil' which implies it is a 'reverso' type that uses the punches as stumps (that's what the obviously larger hole on the baseplate is for). This would need an extended base to allow the punch to stand upright as a stump. With the two photographs I have of the set, I can't quite determine whether there's an extended base in the box or not. Failing that, perhaps I can make something to allow this or even buy an expensive Bergeron base that doesn't quite fit.
2 hours ago, caseback said:
Interesting. I wonder why I didn't see these when I looked. Hopefully these are a compatible size for my set. Worst case, I could maybe make a spacer brass sleeve to fit in the anvil to take different punches.
You could make something, the extra base clicks into the frame and the through hole needs to be in direct line with the hole in the anvil. I wouldn't buy anything but the factory made base. Buying the stumps might be a better, i cant say I've ever seen the bases come up for sale separately, I've been looking for a base for my Star tool for years.
Also, as I only learned about 3 days ago, Cousins sells individual stumps & punches of the types supplied with modern Bergeon staking sets. Single stumps are only around £10-12 so buying the ones you need is not the most expensive path to take.
Regarding the cost for stumps and punches of about £ 10 /pc, a well equipped used set seems lower cost in the end.
A big set contains about 120 - 130 punches and stumps.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
