This is so weird.
It's 4:10am, I got up to use the bathroom and noticed my ancient Smith's electric table clock showed 12:25.
Then I noticed the second hand running super fast. I used my phone stopwatch to time it and it was taking 30 seconds to complete one revolution.
How can that be??? 🤪
Synchronous motors running speed are dependent on the mains frequency. I looked at my bedside radio clock, which also depends on the AC frequency for timing, and that's showing the correct time???
Then I start to worry. Is something in my electrical system that is arcing and causing spurious mains signals?
I unplug my Smith's clock and plug it into a different wall outlet and it's running normally. Really weird.
I'm going back to sleep.... brain not working....
Goodnight!
I found that the clock runs fast when I plug it into the socket that has a built in surge protector.
I took apart the surge protector and found that it only has 2 components inside, a gas discharge tube and a metal oxide varistor wired in series across the L and N line. Something must have failed and clamped the voltage above a certain value and affected the motor.
The clock runs fine when plugged directly to the wall socket.
