Hi I’m working on my first project watch had a few problems mainly with the click spring on the train bridge. I am looking for a Calender ring spring can anyone help me.
42 minutes ago, AndyGSi said:
Yes, what cal is it as the 602 doesn't have a date.
Edit
So it looks like a 612 but no look with parts at the moment.
Smith parts are like rocking horse poop, which is why i buy just about every Smith watch i come across
Hi guys. All I know is there is Cal 602 on the movement. This is the first watch I’ve worked on so I am really at the beginning of the curve. I have brought a packet of springs from Maddison’s of Durham which seems a good place but there isn’t one exactlay matches. I have bought some small players and cutters plus a pin vice to try and modify one with mixed succes.
Ive got both the 612 and 602 spares let me have a look and see what we have going on. Back in 10.
So it seems the 602 was used either with or without the calendar works depending on the dial variation. Due either to manufacturing decisions or a watch guy choice to swap the movement for whatever was available . I'll go with with the factory as i have more than the 2 examples i show . No they aren't for sale 😅, smiths are my main watch passion, so you better be quick with your ebay finger because I'll be right alongside side you bidding for a donor. 😅
So yes the 602 is set up for a dial date complication. The 612 i will look into for the difference.
I'll pull the spring later today when i have more time, will give you a pattern to work to, i may actually have matching springs in my stock. If i have I'll send you one if not I'll make you one, close enough to work with.
Apologies for the late comeback,  my memory is terrible these days, I'll drag that spring out while i remember and see what i can help you with.
You're in uk i assume you mentioned 50 quid in your intro. 😵 50 quid to change a 2 quid battery, i need to set up shop 😅
🤔 i can see the spring for the date ring in your photo ?  Is this one that you've modified ?  Was the original one missing ?
This is the spring, pretty basic shepherd's crook, let me know what you're looking for.......and if you say a busty blonde.....then its too late i already have the perfect match 😅
And no its not Sam Fox that we keep seeing in the lingerie ads at the top, mine is far better.
Edited by Neverenoughwatches
Hi I’m really struggling to get this bridge install over the gear set whilst stopping the click springpinging out. I have managed it twice but I can’t seem to perfect tbe skill. I can spend hours fitting the spring into the recess turning it over and aligning tbe gears but failure. I’m thinking there’s is something I haven’t seen but it’s so difficult to get this in. It’s an Ingersoll Cal 602. I’m running out of donor springs and the ones I change from other click springs don’t seem to be accurate enough and are worse. I’d love some help here. Regards Andrew
1 hour ago, caseback said:
Have you tried pinning it down with a piece of rodico?
Yes I’ve tried that but there’s so little of the spring sticking out.
🤔 i dont remember any difficulty with them....i thought you'd give up so i reassembled it and put it back in storage 😄. Let me see whats going on, I'll pull it back out....yep i know that sounds way wrong.... what I can say I am what I am🤷‍♂️ 😅
A suggestion...
Why just not assemble without the spring and put it after all is assembled (without the screw or whatever goes in the hole)? Not that I have tried - never touch such movement, but it seams like it is meant to be done as I say.
Edited by nevenbekriev
29 minutes ago, nevenbekriev said:
A suggestion...
I'd thought the same thing but it looks like the click would be in the way when the bridge is fitted?
Edited by AndyGSi
Hi yes, I’ve sorted the date spring that’s fine it’s just the click in the bridge. The spring in the image is upside down. The spring fits into the little recess under the bridge so virtually impossible to fit after the bridge is in place unless it works by just being trapped with the screw. Yes, I even thought about fixing it in with a spot of glue but is this “ Cheating”.
Yes. I have had one fitted ok and the click has to drop over tbe lock ratchet which is so difficult.i have seen so many donor movements so I’m thinking there must be a thing I haven’t seen.🤔
10 hours ago, nevenbekriev said:
Seems to me that it will get in, but let OP make a try.
OP, didn't get it? This is answer to the previous post by @caseback
A suggestion...
OP, did You try this?
On 11/9/2024 at 7:28 AM, nevenbekriev said:
A suggestion...
Hi, I’ve worked on that and it’s so easy. I assembled the gears and the bridge screwed it all down and then slid the spring in behind the  gear lock. Once I’d push the spring in as far as it would go I took the screw out and push the spring a bit further so I could see it then I put a fine needle in the hole to pull the  pin across. The great thing is it kept the spring located in tbe recess. Putting the mainspring in and tbe gears, bridge and click spring took me 20 mins. I’ve been trying this for weeks on and off. I never even lost tbe spring. Thanks again. I can’t believe I didn’t see this but I didn’t think there was enough room. That’s the difference between knowing what you’re doing and an “ Old starter” . Thanks again.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
    • The case back is perfectly aligned to the case and has no provisions for a screwing tool. The T-Sport series has snap on backs.
    • For me the text looks too aligned and with no obvious way to grip as a screw back.
    • There’s no indents & there’s no little groove to pry it off anywhere! So I don’t know if it’s screw down or pry off 👍
