Le Coultre??
transporter
sometimes watch companies are really good at hiding that they made the movement. Then of course sometimes really good at not putting markings on the movement. I once found the Le Coultre under one of the bridges a place where you normally wouldn't think about looking to find it.
then one of the ways helpful when looking for a balance staff is if you have the dimensions. Usually the cross reference sources will list dimensions and even if you can't find your model number you may find that one of their other staff may be of the right dimension as they don't always fully cross-reference everything. Or basically you're lucky you use the same staff in another one of their clocks
Digging around it seems to be on the cal. 222 base, I also saw one marked 228 with the same bridge layout. Didn't see a staff for it anywhere, but you never know- it's worth calling and asking at material houses sometimes. Jules Borel list the staff as compatible between 201,202,206,207,208, 19.41 and 22R movements.
Edited by nickelsilver
