Clock not working
Very surprising if you need them all? What is the issue you’re seeing? Tom
I forgot to upload the picture. These are the kind of watch jewelry I'm looking for.
Which jewel is it you're looking for so we can advise if you just have to get a generic one or a specific one.
I'd just use a standard case back hand tool with either some Kapton tape or the silicone paper from the back of a label as protection.
By watchweasol · Posted
The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools
