Elma RM90 circuit diagram
Hi all, good morning.  I'm repairing an Elma RM90 at the moment and I believe I have a fault on the main circuit board.  Does anyone happen to have a circuit diagram for the actual circuit board/main PCB.  Note this is not the general machine circuit diagram thats available on Cousins, I already have that.  The PCB looks pretty basic so should be repairable.  My main suspects at the moment are a pair of Triac transistors that dont have a heat sink.
I also have an Elma RM80 for sale if anyones interested.  Drop me a PM.
Thanks in advance.
Mike
HI @MikeEll and @Ronp,
I might have an opportunity to get a used RM90 for an incredible price (450 bucks) from a local watchmaker... the only thing is that the timer doesn't work. According to the watchmaker, it is still usable in the current state. One just has to push a botton or so to manually switch the jar / advance the programme.
I'm wondering in terms of eventually repairing the timer, can you give me and info/advice?
Best,
C
PS: do you have the full manual of the RM90? Not only the circuit diagram, I mean.
Best,
C
these machines are very basic internally.  Very simple electronic components that can be tested and replaced.  Finding a replacement timer may be a little tricky, but not impossible.  I'd go for it personally.
On 10/26/2024 at 7:48 PM, Ronp said:
I hve the original schematics.
Good luck,
Thanks Ronp, but thats the machine general schematic, not the circuit diagram for the main board that I'm looking for.
Mike
Edited by MikeEll
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
