I'm thinking about buying this tool:
It is said it helps work on balances plus a lot of other uses. Can you guys illustrate/explain those different uses and if possible with support of pictures.
Much appreciated and thanks in advance,
Cheers,
Bob
I have looked at this tool many times. The idea is to secure hairspring stud while pinning a new hairspring to it I think.
However I think it would be very handy when manipulating a hairspring. The cost as always put me off
This tool might do the same job on the bay item number 311482941796
Thank you clockboy! As always good advise and info!
Cheers,
Bob
PS. I wonder if working with that tool can be illustrated with pictures...something like a project or procedure?
Another very useful post John, thank you. I'm surprised the Platax tool is not shown.
Might be because it is no longer manufactured. Highly recommend if you can find one though.
What's interesting is missing tools for removing the balance staff plus his staff grinding tool extremely expensive and if you're not careful bad things happen. Specifically if you're not careful you grind more than the staff and you make a nice hollow into the balance arm. Then if you are grinding out it's always good if you would measure which are grinding out just to make sure that whatever you replace with exactly matches.
Then as pointed out Missing is the Platax tool I've attached photos of something else that's missing.
