Dull clock gong - no ring to it
MikeEll
I’m in the final stages of repairing a lovely grandmother clock.  I’ve noticed that the gong, a spiral circular type, has no ring at all to it.  It sounds totally like a flat piece of steel with more of a thud than a ring to it.  I’ve no idea how these are made or what heat treatment they are subject to.  Is it possible to get it ringing again or shall I look to replace it.  Thanks all.
Check that nothing is fouling the gong. Have you tried bending the hammer away from the gong. What is on or in the end of the hammer? If it is leather and gone hard that will cause problems, if it is the case then the way of dealing with it is to brush oil onto the leather to soften it but it will take ages to sink in in fact probably months.  Photos would help. The case can make a difference as well, depending on the style and the wood.
the gong is out of the clock at the moment.  No fouling issues or anything like that.  You know how you can give the gong a light tap with a pen or similar, you'll get a ringing sound normally.  This is like tapping a wooden table.... nothing, just a dull thud.
With it out of the clock it's doing what I'd expect.
The gong is out of the clock at the moment.  No fouling issues or anything like that.  You know how you can give the gong a light tap with a pen or similar, you'll get a ringing sound normally.  This is like tapping a wooden table.... nothing, just a dull thud.
That is the sign of a crack in the gong so you will need to replace it. if you can post photos I can have a look for you.
yes I think you're right.  There's definitely something odd about it.  I dont think I can share a video on here, I've uploaded to Youtube so you can hear what I mean -
WhatsAppImage2024-10-25at17_21.15_4ffa1d6e.thumb.jpg.18fe1754c0ebbceab6c59576bef56389.jpg
Edited by MikeEll
