Book help
transporter
Does anyone have this book? I’m looking at buying it but it’s a hefty price tag, over £100 but if it has what it says then it will be a great help for a project that I have.
Would anyone be able to say if it has the engineers drawings to the workings of the clocks, ie how the compound pendulum is fitted and parts etc.
many thanks
2 hours ago, oldhippy said:
There is a hell of a lot of info about compound pendulums on the net and it is all free.
If you are a clockmaker it is high unlikely you will get to work on such pieces.
Well, here is the one awaiting my attention.
I have found some information but would like to find the fine details for certain components that I’m going to have to make.
may well end taking it to the next BHI meeting to see if any members locally have any information.
but if you could point me in any direction web wise for info please do mate
In all my time as a watch and clockmaker nothing like this came into my workshop. It sure is in a heck of a mess. From what I can see it is French from the pictures the case doesn't look complete but who knows under all that dirt and grime. Have you looked at the movement to see what it is like the pivots and pinions I would think are rusty. You need to take loads of photos and contact someone from here. If you have never bought a copy of this mag I advise you to do so. They will be able to help you
http://www.clocksmagazine.com/
Yes its a one off, long term project, to be fitted in between customer work as and when I have the time. From the little information I have found it is missing the pendulum ( which I will make) and a few suspension springs that will also need to be made, the counterbalance weight in the tower has a bent shaft that will need to be straightened.
The linkages all move freely and the screws that I have attempted to loosen up have all come free, this is due to them being brass and not rusted steel items. As for the movement its a standard french drum strike movement so wont be too troublesome, I have had many across the bench and also re-pivoted many arbor assemblies so should be reasonably straightforward to get back to working condition.
I guess i will purchase the book the the off chance that it hold the information that I require.
many thanks
Ask to see the index and a few page examples, it might give you some idea of what is detailed, at 100 quid I'm sure the seller will oblige.
  • 4 weeks later...
    • Dear WRT Community, My name is Ben, I am a watch enthusiast learning about watch servicing and repair thanks to Mark‘s course. I started a while ago and I am progressing at a very slow yet enjoyable pace. I look forward to exchanging with you on this forum! Ben
    • I wonder if they ever got the back off, dug mine out today for a change.
    • …here’s a factory shim on a supposedly high quality movement…as I said it’s a lovely shim, though…
    • Bending the balance bridge does seem to be an acceptable method as is taught in school and after all the Swiss make a nifty tool. But? Something was bothering me this discussion has gone on for five pages for one watch? One of the things we have to be very careful about when teaching watch repair on a discussion group is our observations of what's going on is based on the posting person making observations. The problem is if the person making observations does not actually grasp 100% what's going on will we become the idiots? so for instance bending the balance bridge why would we do that? Typically if it's been bent by somebody else and were restoring it back to wherever it's supposed to be. Or basically the Swiss are using it to fine tune the end shake. But it appears to be if I'm reading correctly we have a variation of 0.5 mm which is not a minor amount of end shake. this is where when you read five pages of discussion it becomes kind of a confusing mess so I would not recommend bending the balance bridge until we figure out exactly what's going on. So while I'm not a big fan of shimming which is extremely popular with @Nucejoe I do think it's perfectly acceptable until we actually figure out what's going on.
    • ? I don't know what you mean holds the arms ? The internal spring in the spindle should allow it to hold up to the rivet and the hub of the staff. But that means taking off both the collet and the rolle. With a figure of 8 calipers that have the correct nibs fitted you don't need to do that to true a balance wheel.
