I know this is probably far fetch, but does anyone know the tailstock taper of a Moseley lathe? Last night I spend about an hour setting the taper slide on my Taig to match it as best as I could, and I've gotten close, but not exact. If not, I will probably end up making a collet spindle for my tailstock. I'm just running out of stock to try to match the taper. I think I'm at 3°-64", but the Taig has no reference marks on the cross slide so, its all eyeballed. I've also set up a dial indicator on the cross slide and measured it that way, but I'm about 0.015MM out of square, and the inside of the taper isn't very smooth at this point since its been heavily used, so its hard to get a good reading. If all else fails, ill set up a tool grinding post and make a few spindles, so if you need one, reach out to me.
Thanks in advanced
Thanks in advanced
Lathes UK have a huge database,  there are a couple of Moseley lathes listed there , you might pick up some info.
9 hours ago, rjenkinsgb said:
Do any of the sizes & angles in this page make sense with the measured taper?
https://littlemachineshop.com/reference/tapers.php
More info here:
https://en.wikipedia.org/wiki/Machine_taper#Types
I think some are close, but from my research, each lathe maker had their own taper. So to combat this, I decided to buy a bunch of O1 tool steel rod and will make my own. That way I can set the taper to a known degree, and make quite a few spindles that I can make attachments for. Ill also be making a bunch of dead centers and drill sockets. Setting a taper in a cross slide is a pain. I wish my Taig lathe had a rotating headstock like the Sherline, but i didnt want to pay Sherline prices.
  • 5 months later...
Ill give a little update to this as well. The taper for a Moseley tailstock spindle is around 1.7 degrees. It took a lot of fiddling and testing with a dial indicator, but I got it set to accept some brass sockets.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
