So I received the Seitz tool from ebay but one of the two index pins that are under the micrometer is stuck in its hole. They have a spring under them that pushes the pin up as the micrometer is screwed up or down.
I tried putting a drop of oil in and then a drop of liquid wrench, let sit overnight hoping the spring would pop it up but no joy. I tried heading up the outside a little with a hair dryer and then with a screwdriver turned the pin left and right a bit but nothing. the fact that I can turn the pin says it's not seized up.
I suppose the Swiss make a watch size easy-out but there must be a better way. Any ideas?
22 minutes ago, Klassiker said:
I had a similar problem. See here:
Ultrasonic, didn't think of that.  I'd be a bit concerned about the finish but pahaps 2 or 3 minutes in a water solution would not hur it.  Thanks, I may give it a try.
10 minutes ago, AndyGSi said:
Drill a small hole in it and then either use a screw extractor or wedge a taper in it to pull it out.
Ok, so I took the smallest drill bit I had and drilled down and after a bit it came out, spinning with the bit.  Thanks. I actually drilled through the top and into the cavity where the spring rests.  No big deal and I can always shop for a spare.
The only thing I think I need to do is somehow clean out the hole a bit.  It's 4mm and both pins are a bit tight in spots as well as a pusher I tried from the set, so there is corrosion or dried up oil on the cylinder walls I guess.
Any idea how to best do that?
    • Update!  I've dismantled it, cleaned all the glue off, and rebuilt and lubricated the base movement. I'll leave the chrono part for another day. It's running well - great amplitude and keeping time, but it's got a beat error of 4.8ms.    How important is it to correct this? I'm worried that the potential for making things worse having to take the hairspring off and on repeatedly to adjust this. Would anyone here accept it at that?
    • Since I've been banned from the previous discussion, apparently my language was inappropriate...for small boys. I will start another thread and act in a more decent manner for the girls and ladies of the group.  Please what will happen if the forum can't be managed by the administrator, are there provisions in place to preserve the achived member's questions and answers over the years. Please if I may ask these important questions that are important to the members please.
