Bent pivot on the anchor (aka verge)
LittleWatchShop
Been a little quiet lately...busy splitting my life into two physical locations...
My friend brought me this clock to fix and I figured it would be a no brainer.  Then I discover this bent pivot.  If it were on a regular wheel, I would chuck it up in the lathe and make it right.  But on the anchor...I guess I have to disassemble it.  Not excited about that, frankly.
Any random thoughts?
I decided that, for a pivot that never makes a full rotation...perhaps only 20 degrees...I would just assemble after cleaning and see how it goes.  It is running nicely!
Anybody ever seen a solid escape wheel??
BTW, this is an E. N. Welch.  I date it somewhere between 1885 and 1899. In 1903 Welch was taken over by Sessions.
Edited by LittleWatchShop
2 hours ago, oldhippy said:
There not the easiest of movement to work on. You should try putting one together without spring clamps. I did for a bit of a challenge it took hours.
I am not familiar with spring clamps. When I assemble clocks, I just hold the plates together with my hand while nudging each wheel with a special tool until they are all in place. The tool has a tool on one end and a notch on the other.
