Just got this yesterday, a G Boley bevelled bed type in pieces.
The plating is starting to wear through in places, but it is generally quite clean and after adjusting and oiling the headstock bearings, they seem to still be in perfect condition. Pretty good for being around 100 years old??
I got a faceplate with it, and one collet. There is no centre in the tailstock, just the tubular clamp. The tailstock bore seems to be around 6.6mm ?
I need to either find or make a cross slide or rest for it.
The only bits that are missing are some of the brass washers from the clamping screws, and the pin for the indexing arm - both easy to fix.
I am curious about the collets. A lot are advertised as "6mm", however the parallel section on these is actually 6.5mm; is the 6mm the thread size, or are they a different standard?
In my research Rob there 3 main collet sizes for this style of lathe as well as the dbar Geneva style.  6, 6.5 and 8mm. 6 & 6.5 are no longer made anywhere, some 8mm like WW are still made new. 6mm you see fairly regularly on the bay, 6.5 are much rarer. Hopefully one of our more knowledgeable members will add more.
Tom
    • The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools
    • I don't think I need to know more about the question now, so please don't write anything related to the topic. Thank you to everyone who wrote. Have a nice day.
    • It's an exhibition back so no access as you suggest.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
