From some very quick research, it seems the Swiss Tiffany company shared the Patek Philippe factory at one time, and used their movements.
That serial fits the Patek Philippe movements, and would put it early in the 1905 - 1910 range. Info from here:
https://german242.com/en/patek-phillipe-cie-geneve-serial-numbers/
The movement does appear to be similar to Patek Philippe ones from circa 1900, as this one:
https://somlo.com/products/18ct-yellow-gold-hunter-case-minute-repeater-pocket-watch
2 hours ago, Luismartinezdecuba said:
Hi everyone,
I would like to know the year this pocket watch was produced, and the swiss house that manufactured the movement. It is a Tiffany & Co. Pocket Watch with ref# 124931
Thank you so much in advanced.20241102_153330.thumb.jpg.ab64e66853bd1f48989ac93fc54b2781.jpg
you'll need to take more of it apart to find out yourself , so unless someone does recognise it. nice pocket watch , lovely finishing on the movement.
it had to be something really high end rob, its beautiful, looks like it has a cracked jewel though,   maybe the light ?
I dont know much about pocket watches, so would love to know what all the gubbins is on the left side,  something fancy going on with the dial ?
Ah minute repeater .
I hope the owner has this insured, if not it should be. If the case is solid gold it is worth a few thousand. It will depend on the K Gold and weight.
Edited by oldhippy
You should be able to get a replacement jewel from a good supplier, the wheel will have to be made. I don't know how things are in the U S A for things like that.
There are producers in the US qualified and capable of making parts appropriate for a high end watch like this..
5 hours ago, Luismartinezdecuba said:
Yes, case is 18k Gold. I would love to replace the damaged wheel and jewel. Is there a way I could source those parts?
Sorry for the question, but, do You know how to replace such jewel? It is rolled one and not pressed like modern jewels. You must not screw up the way the movement looks by deforming the stone seat or leaving any kind of marks there. This is not a movement to learn on.
  • Like 10
I would like to second a point already made by a few others, just so it's clear. This looks like a real collector's item, and worth more than perhaps you realise. I advise you not to attempt anything yourself and to get professional help with it.
2 hours ago, nickelsilver said:
If you are looking for someone in the U.S. who can make the minute wheel and replace the jewel, Matt Henning is excellent.
Yes I was recently in touch with Matt and he his both qualified and personable…
13 minutes ago, Luismartinezdecuba said:
Thank you all for your advices. I will try to contact some professional watchmakers here in FL to get some quotas. Cheers to you all!
Ernest Tope would be the man down there, he does very nice work.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
    • The case back is perfectly aligned to the case and has no provisions for a screwing tool. The T-Sport series has snap on backs.
    • For me the text looks too aligned and with no obvious way to grip as a screw back.
    • There’s no indents & there’s no little groove to pry it off anywhere! So I don’t know if it’s screw down or pry off 👍
