From some very quick research, it seems the Swiss Tiffany company shared the Patek Philippe factory at one time, and used their movements.
That serial fits the Patek Philippe movements, and would put it early in the 1905 - 1910 range. Info from here:
https://german242.com/en/patek-phillipe-cie-geneve-serial-numbers/
The movement does appear to be similar to Patek Philippe ones from circa 1900, as this one:
https://somlo.com/products/18ct-yellow-gold-hunter-case-minute-repeater-pocket-watch
2 hours ago, Luismartinezdecuba said:
Hi everyone,
I would like to know the year this pocket watch was produced, and the swiss house that manufactured the movement. It is a Tiffany & Co. Pocket Watch with ref# 124931
Thank you so much in advanced.20241102_153330.thumb.jpg.ab64e66853bd1f48989ac93fc54b2781.jpg
you'll need to take more of it apart to find out yourself , so unless someone does recognise it. nice pocket watch , lovely finishing on the movement.
it had to be something really high end rob, its beautiful, looks like it has a cracked jewel though,   maybe the light ?
I dont know much about pocket watches, so would love to know what all the gubbins is on the left side,  something fancy going on with the dial ?
Ah minute repeater .
I hope the owner has this insured, if not it should be. If the case is solid gold it is worth a few thousand. It will depend on the K Gold and weight.
Edited by oldhippy
You should be able to get a replacement jewel from a good supplier, the wheel will have to be made. I don't know how things are in the U S A for things like that.
There are producers in the US qualified and capable of making parts appropriate for a high end watch like this..
5 hours ago, Luismartinezdecuba said:
Yes, case is 18k Gold. I would love to replace the damaged wheel and jewel. Is there a way I could source those parts?
Sorry for the question, but, do You know how to replace such jewel? It is rolled one and not pressed like modern jewels. You must not screw up the way the movement looks by deforming the stone seat or leaving any kind of marks there. This is not a movement to learn on.
  • Like 10
I would like to second a point already made by a few others, just so it's clear. This looks like a real collector's item, and worth more than perhaps you realise. I advise you not to attempt anything yourself and to get professional help with it.
2 hours ago, nickelsilver said:
If you are looking for someone in the U.S. who can make the minute wheel and replace the jewel, Matt Henning is excellent.
Yes I was recently in touch with Matt and he his both qualified and personable…
13 minutes ago, Luismartinezdecuba said:
Thank you all for your advices. I will try to contact some professional watchmakers here in FL to get some quotas. Cheers to you all!
Ernest Tope would be the man down there, he does very nice work.
