What have I done to my balance?
I've just done the free oscillation test with the pallet fork removed and the pallet bridge in place. It is now oscillating for more than a minute in both dial up and dial down.
The end shake is still more than it needs, I think, and certainly more than the end shake on the pallet, but it has reduced and does not now go as low as it did. I filmed the end shake check, concentrating on the lower pivot. I wonder whether I should disassemble the balance cock again to see if the upper setting can also be pushed in a little. That might reduce the end shake a bit more, but I also wonder whether there's anything to be gained by doing that given that the alignment with the pallet fork is good even at the extremes of travel.
16 hours ago, nevenbekriev said:
What looks like that divot in the endstone?
There's a photo above in my post on Saturday.
The stone can be replaced, but can be lapped too.
I hadn't considered lapping the stone. Is that something a beginner hobbyist is likely to be able to do successfully? What's involved -- is it just rubbing on successive grades of diamond lapping film?
Now the things are much better and I expect the movement will work normally. Yes, the end shake is still big. It is worth trying to push the cock setting, but it holds in place the regulator and stud carrier and if  the setting has shifted, they probably should get loosened.
The stone lapping can be easier done with diamond paste like 10 microns on brass or soft iron plate. You just press and move the stone on the surface with finger.
I guess I'll order some 10 micron diamond paste and get a piece of brass from the local hardware store and give it a try. The alternative is to replace the stone so I really have little to lose by trying it. Thanks for the suggestion.
I don't really want to take the balance off the cock again, but it makes sense, I think, to make sure the Diashock setting is properly seated so I can at least say I've done all I am currently able.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
